Difference between F1 and F6 (1952) - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 05-01-2009, 10:43 AM
VistaGT VistaGT is offline
VistaGT is starting off with a positive reputation.
Quote:
Originally Posted by Julies Cool F1 View Post
Back pressure? Are you kidding? The only thing that feels any back pressure with this set up is the Chebby I'm blowin off the road in the lane next to me.
Yep at 3 1/2 inch diameter the pipes are plenty big. They have a built in muffler but do have a very low throaty rumble! When I'm in a mood I love driving through the market parking lot and setting off all the car alarms
And yes they were expensive (I think). I had to have them custom made - the headers and the transition tube (the side pipes are Patriots) all together with powder coating and choming they were $1700 - two years ago.
Yea that's alot--I think the standard 3 tubes with some cheap side pipes work better for me haha!
  #62
Old 05-01-2009, 10:50 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I say put some straight stacks on the big boy!
  #63
Old 05-01-2009, 12:21 PM
^^^^Interestin concept never thought of it, possibility. I called reds headers and they only make headers for F1-F5. Are the F5 and F6 the same, engine bay wise. The steering box is very close to one of the tubes on the F5. Is it the same on the F6 or is the steering box larger?
  #64
Old 05-01-2009, 02:18 PM
bobj49f2's Avatar
All of the engine compartment are the same, F-1 through F-6. The F-4s and up have a larger steering box but that's the only difference other than maybe the vacuum lines that run to the brake booster. Also, on my F-4 I have absolutely no clearance between the steering box and exhaust manifold, I think my engine mount in the front is probably compressed a little. Just take a look at that are in your truck and see if you have any room in there.
Also, when are you going to post pictures of this beast? We all like pictures!
  #65
Old 03-07-2013, 09:09 PM
Originalchick's Avatar
Originalchick Originalchick is offline
Originalchick is starting off with a positive reputation.
Ok, silly question time... Is the F1 the same as an F100? I'm in Australia, and we didn't get the F1,2 etc. There are plenty of F100s, F250s, F350s etc. front the 50s.
I have just bought a 48 F6 COE, shell/cabin only. I'm trying to figure out what type of chassis I can put under it.
Im thinking F100 because I want it to be super stubby, and low and chunky. (Like 48fordcoe green one). And drive more like a car than a truck. I don't want big skinny truck wheels. I want 10 and 15 inch wheels front and back, to fill those massive guards.
A friend suggested putting it on a Mustang chassis, for the independant front suspension.
Any help /suggestions would be much appreciated. There is not much info out there on them.
Thanks
Sally
  #66
Old 03-07-2013, 09:23 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Some of those super low COE's are set upon an Old's Toronado. Not sure of the details.
  #67
Old 03-07-2013, 09:27 PM
Thanks Havi, but I don't know what a Toronado is! Lol. We didn't get them in Australia. I'm trying to avoid importing another thing, by using something that is here.
  #68
Old 03-07-2013, 11:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I know a couple of Aussies on here have F-1's, F-3's, etc. Aussiecowboy for one, and Lexcoe has a COE just like yours. I'm sure chassis for early ones aren't real common but that is far and away your best bet for a chassis to start with.
  #69
Old 03-07-2013, 11:20 PM
I think you will find they imported a whole car in to Australia... Not just a shell like me.
Plus Lexcoe has put his project COE on the back burner.
  #70
Old 03-08-2013, 01:58 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
You info is a bit off Sally, we most definitely did get the F1-6 range here in Aus. I have an Aussie F3 and an F4 and know of quite a few others around. They aren't common anymore as many have been scrapped over the years but they are still out there.
A toronado was an Oldsmobile from the late 60s and 70s, those we didn't get.
  #71
Old 03-08-2013, 02:13 AM
I am selling a 59 F250 short wheel base project truck if you're interested. I'm also parting out the F4 but that will likely be too big for you.
  #72
Old 12-30-2013, 05:13 PM
Tropic's Avatar
Tropic Tropic is offline
Tropic is starting off with a positive reputation.
Quote:
Originally Posted by 51PanelMan View Post
Sorry to post it here since it's kind of off this topic, but I can't send a PM or email to keith1952f6.
I have a complete front 51/52 F2-F6 clip, but it's not in immaculate shape. Not sure what you have now is better or not.
You would be the one to know, will lower front fenders from a normal F6 fit on a COE F6, both being 1952? Also could the upper fender forward part on the normal truck be used to repair rust around the headlights on the COE? In pictures they look the same, COE fenders are hard to find.
I am new here and just getting started, any help would be appreciated.
Will 1948 F2 Front Fenders fit 1952 F3? Scotty's 52 F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 09-25-2015 01:30 PM
1952 ford f1 build sheet?? SparksCCC 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-29-2014 05:31 PM
1950 255ci Flathead Merc in a 1952 F1? kellybeefarm 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 04-25-2009 04:29 PM
1952 or 1953 Ford F3 jfrisby 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-28-2007 03:27 PM
Tags
1948, 1952, 48, 52, booster, brake, difference, f1, f6, fender, fit, ford, rat, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
