Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-26-2009, 12:36 PM
Black88GT's Avatar
Black88GT Black88GT is offline
Black88GT is starting off with a positive reputation.
What kind of generator?
Hey guys, I have an enclosed car trailer, and Id like to get a generator for it. Mostly it would be for lights, and stuff like that. I dont want to get one that in a year be like damn I should have got a bigger one. I saw one at Home Depot for 649. and it was a 5000 watt. homelite. Suburu motor. What do you guys use, and recomend? Thanks!
  #2 (permalink)
Old 04-26-2009, 01:39 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
Another time bigger is better. I bought a Generac 7500w/13500 surge 4 years ago. It has run my whole house quite a few times. Electric start/low oil shutoff even will run my 220v welder. I bought it Tractor supply. You can pick up some real deals on used ones. People buy them and use one time then sell if not using, kind of like snow blowers. Honda's are good but a little pricy.
  #3 (permalink)
Old 04-26-2009, 02:00 PM
conger's Avatar
conger conger is offline
conger is gaining momentum as a positive member of FTE.
3000 watts will probably do what you want. If you need to run a small mig welder in as well, you might want to go with 5000 watt. I don't know if I'd go with homelite or one of those low end ones. Sometimes they can be problematic. My buddy has a Honda and I've got a Yamaha. Both are very quiet - but those are for RVing in campgrounds, so quiet is important. Quiet is also pricy, so if you don't care about the noise then just look at watts and reliability. Good luck
__________________
04 F250 S/C 4x4 6.0psd, Viper security, Procomp ES9000s, Prodigy, Fumoto valve, Dieselsite coolant bypass filter, steel braided esof lines, Cat delete, Procomp 2 1/2" level lift & rear add-a-leaf, Autometer pillar gauges, DC1 rims on MT rubber.
  #4 (permalink)
Old 04-26-2009, 03:28 PM
Black88GT's Avatar
Yes I would need quiet. In case I would run it around my house. What do the Yamahas or hondas run? Would you buy one used?
  #5 (permalink)
Old 04-26-2009, 06:42 PM
conger's Avatar
Quote:
Keep in mind this is in Canadian bucks, but I paid just shy of 1800 for my Yamaha. But it runs at 48 decibels, about the same as a car idling. Very quiet...I like it
__________________
  #6 (permalink)
Old 04-29-2009, 05:37 PM
tinker934's Avatar
tinker934 tinker934 is offline
tinker934 is starting off with a positive reputation.
generators
i have a honda 3000 love it ele start. the old man has a yamaha 2800. you might look on craigslist.com you might find one used that's how i got mine $700. used just took her camping past weekend ran all night like a champ (powerd two trailers all night due to the cold weather bbbrrrr)
__________________
03 7.3 sd swb 2wd w/a 6' rcd kit 4' turboback bullydog,stage1 afe, edge evolution (for my gauges) ats houseing, ww,zoodad delete foil
firestone bags(inner rail) h.i.d lightkit 6.0 IC & TC
IDM =73.2 f6 dp-tuner n/s, stock, decel,60t,80t,80e,140
  #7 (permalink)
Old 04-29-2009, 06:27 PM
J_E_Summit's Avatar
J_E_Summit J_E_Summit is offline
2008 Ford F-250
J_E_Summit is gaining momentum as a positive member of FTE. J_E_Summit is gaining momentum as a positive member of FTE.
Brand name is key. People awlays bring cheap brands to my dad's shop and its nearly impossable to get parts, plus they break down much more often then the brands like Yamaha or Honda.
__________________
Jason
2008 F250SD XLT Chrome Supercab Long Box 5.4L Torqshift
SCT X3 from 5 Star, IQR Headache Rack, BetterBuilt Box, Custom Deckover
BC Chapter Member
  #8 (permalink)
Old 05-04-2009, 12:48 PM
tinker934's Avatar
generator
i just came acrross this Honda EU2000 generator
this would work great just not the AC
__________________
  #9 (permalink)
Old 05-04-2009, 06:02 PM
grafekie grafekie is offline
1995 Chevrolet C/K 3500
grafekie is starting off with a positive reputation.
Honda engines will last forever, but are very expensive. You can get a very nice Briggs 5500W generator from Lowes for about $550-600. They run very well. Most generators are very loud though, you don't want to stand next to them for a long time. There are newer ones that are specifically sold as "quiet" models... they are very very pricy, but if you are working next to it all day, probably well worth the added price.
Also remember that the larger capacity models cost a lot more to run in terms of fuel per hour.
__________________
Nathan
2002 F150 SuperCab Short Bed FX4 5.4L V8 Firestone Load Level Air Suspension - totalled by Spradley Barr Ford
1995 K3500 Regular cab 8' bed 4x4 6.5L
2007 Featherlite 8413 20x7x7' Stock Trailer
  #10 (permalink)
Old 05-07-2009, 11:34 PM
Dually TAS's Avatar
Dually TAS Dually TAS is offline
Dually TAS is starting off with a positive reputation.
Honda EU 3000, or if you don't have or want A/C get the EU 2000. If you buy the 2000 you can always buy another and run them in parallel for enough power to run your A/C. The difference in weight is about 100lbs on these models if that is a factor for you like it is me.
If you will need 220/240 do some more research.
__________________
2005 F-350 Lariat DRW 6.0 PSD FX4 Tow Boss
  #11 (permalink)
Old 05-08-2009, 06:55 AM
The number, is that the wattage? 3000W can run an AC unit? That's just shy of 30 amps 110v.. what do they draw?
__________________
Nathan
  #12 (permalink)
Old 05-09-2009, 08:43 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
SHADE TREEIN SINCE 1957
StanleyZ is gaining momentum as a positive member of FTE.
You don't say what you want the gennie for. If it's to work with any construction type will work. If you're going camping or RVing, please get a quite Honda or yamaha. Those guys running construction gennies in the campground have me cleaning the gun and wondering how long life in prison really is and would it be worth it. The Honda 2000i is around $1000. You can find them at the Rv shows for a bit less (900). If you want to run the air conditioner you will need two, plus an in series wiring kit for a $100 or so. They also have a battery charging kit tor a few bucks. That's the setup I have. I only carry 1 in winter or up to high elevations, and 2 in the summer. They weigh about 35 lbs or so and are compact and easy to handle. Quite enough to meet national park standards, whatever that is. Like someone above said thy run like a car at idle. And, yes i would buy one used from someone who acted like they take care of stuff.
__________________
2008 F350 DRW Lariat/ 4.30 Diff/Titan 60 Gal fuel tank/Bone stock running gear and just a little truck bling.
  #13 (permalink)
Old 05-10-2009, 01:06 AM
Old93junk's Avatar
Old93junk Old93junk is offline
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
Quote:
I am one of those guys running a construction gen. for power...............Not every working guy can afford to drop a big chunk a change on a damn honda, I go to great pains to keep mine as quiet as possible and running as little as possible. I run mine in the gen. compartment of my class C that used to house the too expensive to repair honda gen., with sound deadning insulation and a 12v fan helping to move air into the compartment. I fabed up a long tailpipe out of hyd. tubing and aimed it similarly to the old gen. set-up......Dont lump all of us construction gen. guys into the same class.
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #14 (permalink)
Old 05-10-2009, 07:37 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
I have an 8000 watt that is pretty loud. I've thought about rigging up some kind of sound deadening but am concerned about engine damage from an increase if back pressure or heat or ??? whatever might come into play with a bit more tube, muffler ect.
I have not gotten serious enough to attempt anything. Has anyone tried to quiet down a larger gen? Would it be a problem for a 10 hp engine to add an additional muffler, something that would clamp on when needed?
We need some viable ideas that won't cause damage to an engine!
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #15 (permalink)
Old 05-10-2009, 07:58 AM
Also, you CAN NOT RUN TWO GENERATORS TOGETHER!! Not on the same circuit. So get one that can do the largest appliance you need to power... if you need a second, you have to run it seperately.
__________________
Nathan
Tags
110 , 1800 , 220 , decibels , enclosure , eu2000ia , generator , generators , homelite , honda , linking , opinion , power , run , sound , volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
