40" Tires - How Much Lift Is Required? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-25-2009, 11:34 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
I'm planning to install Bushwacker "Cut Out" fender flares on my 2005 F350 4x4. I want to run 40X13.5R18LT tires and need to know how much lift is required for proper clearance.
Here is a guy who only has 2.5" leveling kit and 38" tires:
008.jpg picture by Gregch_photos - Photobucket
007.jpg picture by Gregch_photos - Photobucket
Here is a guy with no leveling kit and 36" tires:
Truckblog - Photo
Truckblog - Photo
I want an Icon lift kit and believe that a 4.5"-5.5" lift kit will be sufficient. I'm not using the stock front bumper so I'm not worried about rubbing issues there.
Is my assessment correct? Do I need a 7" lift kit?
Thanks!
Old 04-26-2009, 06:48 AM
high ho silver's Avatar
high ho silver high ho silver is offline
high ho silver is gaining momentum as a positive member of FTE.
35s, 37s, 40s....leveling kit, 4" lift, 7" lift. Man you are all over the place!
Old 04-26-2009, 11:01 AM
Furian's Avatar
Ha! I provided the pics for references purposes only. I cannot find any pics of a Super Duty with cut out fender flares and 40" tires.
I want to run 40" tires.
Old 04-26-2009, 11:53 AM
DieselBeast01's Avatar
DieselBeast01 DieselBeast01 is offline
DieselBeast01 is gaining momentum as a positive member of FTE.
To get 40s on it you will have to put some kind of lift. I don't think that they will fit without some kind of lift.
Old 04-26-2009, 12:23 PM
in heat's Avatar
in heat in heat is offline
in heat is starting off with a positive reputation.
my excursion had 6" of lift and 37" ssr's and I still had to cut the bumper, so my thought is 4.5"
and the cut out flares should be plenty, the cut out flares remove a lot of material.
Old 04-26-2009, 01:06 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
The 4.5" kit should be plenty to clear 40s with the cutouts. I think cutouts and 38s-40s might be in my distant future
Old 04-26-2009, 01:13 PM
Furian's Avatar
That's what I was thinking too... 4.5" lift kit. The more I look at lifted Super Duties, the more I'm seeing that the greatest obstacle is the lower corners of the fender wells. They're just too narrow for any tire greater than 35 inches. So you have to add lift to place the lower corners of the fender wells "above" the tires. The cut fender flares allow the truck to sit lower on larger tires, which should allow for better handling (lower center of gravity) and practicality (lower bed height). I'm 100% sold on the idea!
Old 04-26-2009, 01:35 PM
Now, are you going to paint them white or leave them black? The ones's I've seen black on light colored trucks make it look like a huge black hole in the side of the truck, so if I do cutouts mine will be painted.
Old 04-26-2009, 01:45 PM
Furian's Avatar
They will definitely will be painted for the reason that you stated. I have a tan interior. So, I'm going to add a lower accent color (probably gold, maybe copper). So I'll be painting the lower section, front and rear bumpers, and the cut out flares.
Old 04-26-2009, 02:22 PM
I wish mine had the accent panel, then I would have powdercoated my bumper that color instead of white. I like it white, but its a bear to keep clean and any pin holes or rock chips get rust stains on them. Doing the gold accent color will look good, much like the truck in Bushwacker's pictures.
http://www.supertruckusa.com/product...2F26234-lg.jpg
Old 04-26-2009, 02:32 PM
Furian's Avatar
Yeap! The gold accent is "classic" on the Ford trucks and is always in style. I found a decal provider online that accomodates many font styles and will replace & add some to the truck. The "4X4" will go on the bed and the "5.4L 3V ENGINE" will go on the hood.
http://www.signspecialist.com
Old 04-27-2009, 10:26 AM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
If you plan on wheeling....they'll be close under a 4.5", being skinny they will probably just clear.
If you don't plan on wheeling, they'll be fine.
I know guys who ran 8" lifts and 40" Hawgs with cut-outs and could stuff them, but the Hawgs are wider.
And I still don't think a 13.50 is going to look right under the cut-outs.
Old 04-27-2009, 11:44 AM
Furian's Avatar
If needed, I'll add the Icon 1" spacer and appropriate rear block to add additional lift. Are you recommending a 7" Icon lift for true off-road clearance?
As for the width of the tire, I personally like the narrower (not skinny ) look of the 13.5" wide tire. To use 15.5" wide tires, I would have needed 12" wide wheels and the stress of the wider footprint would have been significant on my 5.4L engine.
Old 04-27-2009, 11:49 AM
A 13.5" tire should look fine as long as the wheel offset puts it far enough out so its not tucked under too far.
Old 04-27-2009, 11:57 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
correct me if I'm wrong, but with all that turning mass, won't the 5.4 turn those tires at a snails pace ? shouldn't more gearing be considered ?
just trying to hep here
kennebell dyno graph and some pics V10RP Modular V10 (6.8l) 9 11-22-2014 10:33 PM
Ex on the sand in the Outer Banks PICS nghtrgr Excursion - King of SUVs 29 10-20-2009 03:01 PM
R12 to R134a conversion 1992 F-150 4DConsumer 1987 - 1996 F150 & Larger F-Series Trucks 1 06-03-2009 08:46 PM
Installed K&N CIA Kit - 2005 F350 5.4L Furian 1999 to 2016 Super Duty 33 05-27-2009 08:40 PM
Clean Pics with New Mods. DCSpecial 1999 to 2016 Super Duty 30 03-27-2007 02:22 PM
Tags
2004, 40, 50, big, bushwacker, clear, cut, f250, kit, lift, needed, run, superduty, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
