I just got the truck a couple of months ago. I noticed today that I had a black battery cable that was behind passenger battery and ran in front of the radiator and back behind the drivers headlight. Both ends are un-hooked. Drivers side battery the neg. goes the the firewall and the pos goes to another starting cylinoid. Should the neg of both batteries be connected?
78 F350 I messed up. The main battery neg is hooked up. But there is another cable that runs from one batter to the other that Isn't and was wondering if it is supposed to be. Can I hook it up and remove the neg wire going to the fire wall?
The battery on the drivers side is the auxillary battery... for campers or trailers...and the solenoid on the drivers inner fender is not a starting solenoid, its an isolating solenoid so when the engine is shut off, your camper (or trailer) will pull power from just the auxillary battery, not the main starting battery. When the engine is running, this solenoid allows both batteries to be charged. Sounds as though the P.O. had a problem with the aux. battery charging and just hooked the main battery and the aux battery together with a wire to get them both to charge. I'd check that aux battery solenoid on the inner fender to see if its working properly.
