Odometer inop '97 F150, w/tach - Ford Truck Enthusiasts Forums
Old 04-25-2009, 03:55 PM
MIKE I 97 MIKE I 97 is offline
MIKE I 97 is starting off with a positive reputation.
Hi all, new to forum, not to Ford. I've been a FMC tech for 20yrs. I find myself driving a 1997 F150 4.6l auto, had 112,000 on the odometer when it quit.
I'll confess, I've replaced many instrument clusters for this concern, (the life of a dealership flat rate tech) however, I'd like to know if anyone has repaired one. This one is my daily driver and I would like to save a buck or two if possible. BTW, the speedometer works.
Thanks in advance.
Old 04-25-2009, 09:05 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE MIKE I 97! I don't recall seeing anyone posting a fix for this. Have you tried searching the forum for it? Good luck!
Old 04-26-2009, 08:35 AM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Pull the cluster,and visually track down the runs that go from the connector to the Tach connector.
Use a meter,and check for continuity between the main connector,and both tach terminals. if either is open, youve found the problem.Usually it will just be corrosion.
If continuity is good,check across the tach terminals.You should read a low resistance.....Id guess around 10-40 ohms.If this checks good,I figure the cluster itself is good,and the problem would be in the engine compartment where the tach feed comes from.
Hope this helps. I do suggest a Digital DVM such as a Fluke 75/7700 series.
Old 04-26-2009, 06:45 PM
The odometer in the truck is mechanical, not likely to be an eletrical problem.
Old 04-27-2009, 06:06 AM
n5926g's Avatar
Wow...Did I screw up.....I thought he said Tach Inop....Sorry Guys!
Old 04-27-2009, 09:52 AM
MikeD1980 MikeD1980 is offline
MikeD1980 is starting off with a positive reputation.
I have the same problem with my 97. stopped at 70,999. I was going to try to pull the cluster and spin it by hand to get it working again. title already says odometer discrepancy so I am just doing it for oil changes and such.
Old 04-27-2009, 11:47 AM
ddrumman2004 ddrumman2004 is offline
ddrumman2004 is gaining momentum as a positive member of FTE.ddrumman2004 is gaining momentum as a positive member of FTE.
My 97 F150 Lariat with a 4.6 auto has an electrical speedometer/odometer.
There is no cable running to the rear of the cluster, other than electrical cables.
I had my cluster out to replace some burned out lamps in the unit back a couple of months ago. Replaced them all with new ones while I had it out.
Old 04-27-2009, 12:39 PM
I didn't say that it was cable driven, just a mechanical odometer instead of the electronic odometer like in the Lariat and later models.
Highest odometer reading 399,999? tpcgregsheh 1987 - 1996 F150 & Larger F-Series Trucks 15 09-26-2015 06:16 PM
'97 Expedition hood fit '99 F150??? Big Long Truck 1997 - 2003 F150 1 08-08-2014 09:39 PM
Odometer Light Works, but no readout archbot 2004 - 2008 F150 1 05-13-2014 12:59 AM
Tire math and the odometer F150vettehauler 2004 - 2008 F150 3 05-05-2014 02:58 PM
2006 E-250 with one million miles delgriffith 1999 to 2016 Super Duty 41 12-19-2013 10:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
