Radiator Support Mounting Hardware - Ford Truck Enthusiasts Forums
Old 04-25-2009, 02:23 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Hi all,
Radiator Core Support mounting hardware, does anyone know what years are interchangeable.
I need the retainers (Special washers) and am not having any luck finding them, actually I need everything, shims, bolts and all...
Sure would like to find this stuff, Have a new urethane kit, nothing to put it in with!
Thanks
-Enjoy
fh : )_~
Old 04-25-2009, 08:59 AM
uncle.stosh uncle.stosh is offline
uncle.stosh has a good reputation on FTE.uncle.stosh has a good reputation on FTE.
They may still be available from the dealership, but last time I checked they were $$$$.
There really isn't anything special about them. A good nut and bolt supplier should be able to hook you up with some grade 8 bolts and fender washers.
IIRC: the body bolt inerts were $25 each from the dealer.
Old 04-25-2009, 12:43 PM
bfbiker's Avatar
bfbiker bfbiker is offline
bfbiker is starting off with a positive reputation.
Talking ????
Quote:
Originally Posted by Festus Hagen View Post
Hi all,
Thanks
-Enjoy
fh : )_~
So you are saying the Radiator Core Support will come off our trucks somewhat like a van does so you can take out and put in the motor
Dam I have to ck this out so I can put motor and trans as one
All so if any one needs rebuild kit for there AOD trans let me know I have a lead on them and to my door (payed at 5 pm thurs night and was at my door in fridays mail FAST) was 121.00 to the door
Old 04-25-2009, 01:57 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
In installed my engine & trans as a single unit without removing the radiator support, used
a load leveler between the hoist & engine. Got it from NAPA for $40-$50, it's similar
to Garage Equipment Engine Hoist Accessories and Motor Lift Accessory on Sale
Old 04-25-2009, 02:34 PM
bfbiker's Avatar
Talking yep
All ready have one
just have to get the motor and trans at angle that you have to boom the lift all the way out and puts a lot of stress on the lift
so again does it all unbolt like the van does
Old 04-25-2009, 02:48 PM
Methanoholic
Yes, The core support is removable... Is it easy, that all depends on rust.
Also when removing the core support you will have to re-align the front clip.
-Enjoy
fh : )_~
Old 04-25-2009, 02:50 PM
bfbiker's Avatar
Thank you
-Enjoy
fh : )_~
Thanks Festus
Do you have any photos with out the core support
Old 04-25-2009, 03:14 PM
Methanoholic
Yes, I do care about the dollars, but that is on the very bottom of the list.
I want the correct special washer/bushings. (retainers)
As I see/understand the top is a big washer with a hex bushing, the lower is a big washer with a round bushing.
Bolts, nuts and washers are the easy part, I have plenty on hand.
I will try the local dealer, but every time I go there and say 1986 they laugh, and say It's obsolete without even looking.
After some pushing I can usually get them to look some things up, but it's like pulling teeth.
-Enjoy
fh : )_~
Old 04-25-2009, 03:20 PM
Methanoholic
I don't, but I did just see some on this site, now If I can remember where...
Someone did a motor swap and had their core support off with inner & outer fenders still on. Might check the New Sticky (Or Sticky Suggestion Box), that may have been where I saw it.
it'll give you basically a straight shot stuffing the motor.
-Enjoy
fh : )_~
Old 04-25-2009, 03:40 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Last time I checked at my dealer in 2001.
Everything was obsolete except the long bolt that goes through the bushings, and the nut.
And this is with a dealer that I have friends behind the counter, and they take the time to help when they can.
Numberdummy might be able to search for them for you, and tell you either way. I'd give him a PM.
Old 04-25-2009, 05:36 PM
Methanoholic
Thanks
I figure if somebody can and wants to respond they will, if not, I'm not going to force myself upon them...
-Enjoy
fh : )_~
Old 04-25-2009, 07:13 PM
I don't think he would mind. He loves helping people on here. It's just he doesn't visit this forum very often. Usually 1973-1979 forum and older.
Old 05-04-2009, 12:57 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1980/89 F100/350 / F(Super Duty) / Bronco / Body Location #1 = Core Support / Bottom to Top.
2) N800442S .. Bolt-Metric / Obsolete
2) E2AZ5400155A .. Absorber-Lower
MSRP: $9.22 each // FTEpartsguy.com price each: $6.64
2) EOTZ1000396A .. Absorber-Upper
MSRP: $84.03 each (!) // FTEPartsguy.com price each: $60.50
2) 387677S .. Washer 3/8" I.D. x 3/32" thick / Obsolete
2) E6TZ10000145A .. Shim / Obsolete
2) 382552S .. Washer v v / Obsolete
2) N620483S .. Nut-Metric / Obsolete
I did not look in the 1990/2002 parts catalog to see if these parts were used after 1989...but I will...if asked to do so.
I searched and found some of these obsolete parts at Ford Dealers & obsolete parts vendors.
I need to know what large city you live near, so I can list the sources closest to you.
Old 05-04-2009, 09:34 PM
86bigred's Avatar
86bigred 86bigred is offline
86bigred is gaining momentum as a positive member of FTE.
did you try NPD or LMC.i remember in one of those mags there was something for the rad support. just an idea.
Old 05-05-2009, 03:51 AM
Methanoholic
Yea, I forgot to include that, NPD has nothing, LMC has core support hardware, but I really can't tell if it's complete or correct, It doesn't show the pieces I am after, but they may very well be part of the cushions.
It does show the pieces for the cab mounts, they call them a retainer.
If worse comes to worse that is what I'll do is order up a set of them and deal with it.
I really don't want to spend 25 bux a cushion and then burn the rubber off the bushing so I can use it in urethane cushions.
Numberdummy has listed some stuff for me but I don't see what I'm after in his list either. I'm thinking they are in fact part of the cushion from the factory.
This leads me to a belief that the urethane kit is incomplete and should not be marketed as is. It requires the use of these bushings and does not supply them.
They are a washer with a tube... The upper has a hex tube, the lower has a round tube.
-Enjoy
fh : )_~
Need a Shop: Radiator Core Support Replacement warren561 Massachusetts Chapter 4 11-25-2014 05:47 PM
where can I find inner/outer fender bolts Mikes67F250 1967 - 1972 F-100 & Larger F-Series Trucks 10 12-17-2011 01:12 PM
Replacing radiator core support - '92 F150 minnesotafisherman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 08-11-2011 11:54 PM
Solid Body Mounts Bad Idea?? mabigredtruck 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-01-2010 08:08 PM
Changing radiator core support nnero 1987 - 1996 F150 & Larger F-Series Trucks 3 03-19-2009 10:01 PM
Tags
1986, 1994, bracket, bushing, core, eotz1000396a, f150, f250, f350, ford, hardware, mounting, n620483s, pickup, radiator, round, support
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
