Front Bumper removal? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-24-2009, 10:06 PM
c125bob's Avatar
c125bob c125bob is offline
Buy American
c125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputation
I am replacing my bent OEM front bumper. Anybody got tips or instructions? While I'm in there I am going to replace my broken fog light brackets. Had a chance encounter with a Deer, dead center between the tow hooks.
Thanks for any advice so I can avoid some skinned knuckles ! I won't be back on line till late tomorrow but will check for help then ! Thanks in advance.
Old 04-24-2009, 10:33 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
It is easy.. just remove the 4 large nuts next to your tow hooks.. I always wrap the ends of the bumper with tape or something to protect from scratching the bumper when you finally get the nuts loose.. The ends will want to go up and hit the fender paint..
Old 04-25-2009, 02:05 AM
12pump 12pump is offline
12pump is starting off with a positive reputation.
Just like Clint says its easy just loosen all 4 bolts by the tow hooks. I used a bucket, remove one bolt from both sides and then the other bolt and place one side of the bumper on the bucket then the other bolt and done.
Old 04-25-2009, 07:51 AM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Just make sure the brackets holding the bumper on aren't bent. One of mine was when I had a chance encounter with a Buick. Makes the bumper lower on on side.
Old 04-25-2009, 11:09 AM
King0581's Avatar
King0581 King0581 is offline
King0581 has a good reputation on FTE.King0581 has a good reputation on FTE.
Dont forget about the two bolts(one on each side) that holds the brace brakets for the outter ends of the bumper.
Old 04-25-2009, 11:12 AM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
Don't forget about the two side braces on the ends behind the bumper - one bolt per bracket on each end. A second person is a great help when you break loose the last bolt, and the bumper really is not heavy at all, just very awkward.
On re-installation, I personally use a 1/4" thick X 1/2" wide X 10" long piece of wood as a spacer to get an even gap between the bumper and hte grill & head lights. I place the stick under the inside corner of one head light assembly and push the bumper up until it holds the stick in place... then tighten one bolt on that side's tow hook and set the gap on the other side the same way.
Before tightening all the bolts, though, also check your end-to-end alignment with the fender panels and make any necessary tweaks to your alignment accordingly.
Then, tighten the four tow hook bolts and the two end bracket bolts and your done.
Old 04-25-2009, 12:32 PM
Quote:
I guess it depends on the model year.. my early 99 doesn't have these two bolts on the ends... just the 4 large nuts next the hooks..
Old 04-25-2009, 05:10 PM
King0581's Avatar
I have a '03 and it has them. Didnt know the earlier PSD's didnt.
Old 04-25-2009, 07:54 PM
c125bob's Avatar
Buy American
Thanks to all !!!! I'll jump on it when I get my replacement Fog Lights and brackets. They got slammed too. Sounds like it won't be bad. I'll report back when finished. Got the bumper haven't ordered the fog lights yet. Again, thanks folks.
Old 05-02-2009, 07:16 PM
c125bob's Avatar
Buy American
Well, got it all finished up today. New bumper, valance, air dam and fog lights. Thanks to King0851 for fog lights and advice from FTE. It wasn't bad at all. Its nice to have the 250 back in fighting trim. Thanks to all !
Old 05-02-2009, 10:34 PM
It nice when a plan come together and you got her back on the road..
Old 05-03-2009, 09:33 PM
King0581's Avatar
Glad you got it done Bob.
Old 11-24-2009, 01:27 PM
Fire Rooster's Avatar
Fire Rooster Fire Rooster is offline
Fire Rooster is gaining momentum as a positive member of FTE.
Any tips on air dam removal?
Old 11-24-2009, 06:51 PM
Looking to add some LED marker lights to the air dam. Just wonderng if here are ay hidden tabs etc. I need to worry about in removing it?
Old 11-24-2009, 07:42 PM
c125bob's Avatar
Buy American
Nothing to it really. When you get under the truck you can see all the fasteners and how they come off. When you are putting it back on an extra set of hands is helpful but not necessary. Go for it !
05 front end - just the bumper? kitebuz Excursion - King of SUVs 3 01-12-2016 05:17 PM
Show me your aftermarket full front bumper please dmags 6.7L Power Stroke Diesel 1 09-09-2015 09:14 PM
1995 Ford F-150, 5.0L, 4WD, Front Bumper Recommendations OFLM 1987 - 1996 F150 & Larger F-Series Trucks 4 05-10-2015 09:08 PM
1975 Front Bumper Brackets 1975MudRat WTB - Parts & other 6 12-01-2012 04:53 PM
Replacement rear bumper with sensors eldorado73 Excursion - King of SUVs 2 07-18-2012 12:35 AM
Tags
02, 2002, 2003, 2005, 73, bumper, f150, f250, f350, ford, front, installation, removal, remove, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
