Replace and Upgrade Bench seat 1994 - Ford Truck Enthusiasts Forums
Old 04-23-2009, 12:49 PM
DragonDriver's Avatar
DragonDriver DragonDriver is offline
DragonDriver is starting off with a positive reputation.
I know ive read a thread in this forum that says what years for F series and Bronco seats will bolt right into a 94 F150 xtra cab.
But i cant find it.
Im about to start my junk yard hunt for some nice captin's chairs for my truck. Dont want to have to build anything to get the seats to fit but something real "easy" i would keep in mind.
Thanks in Advance guys!
Old 04-23-2009, 06:10 PM
IllRespect's Avatar
IllRespect IllRespect is offline
IllRespect is starting off with a positive reputation.
From what I have read on here. Anything up to a 96 will fit without too much trouble.
Old 04-23-2009, 07:26 PM
1994 F250: 351, C6 1994 F250: 351, C6 is offline
1994 F250: 351, C6 is gaining momentum as a positive member of FTE.
I would try looking for the captains chairs that were available in these trucks. They have a center seat with a fold down center console. My dad has these seats in his '97 F250HD and they are very nice and I am thinking I will swap to these when I upgrade my seat. Anything up to '96 (and '97 HD) will work. Given you have an extra cab, you will not have to many problems getting any of the seats that came in these trucks (plus the Bronco) to fit. If you get seats from a junkyard make sure you get the the track and bracket assembly as well.
Good luck and let us know how it goes.
Old 04-23-2009, 07:58 PM
Thx for info, yall will take some b4 and after pics!
Old 04-29-2009, 09:36 AM
Q in Sac Q in Sac is offline
Q in Sac is starting off with a positive reputation.
I'm looking to upgrade my seats. I searched for seats. Any other resources?
Old 04-29-2009, 10:19 AM
tralfamadorian tralfamadorian is offline
tralfamadorian is starting off with a positive reputation.
It seems to me that if you are going from bench to buckets, that you would need to drill some additional holes for the buckets.
Old 04-29-2009, 12:58 PM
Im having fun pulling my bench out and trying things with the Centurion seats i bought. I mess around for a few hours and then have to put the bench back in so i can drive it. So far i have tryed taking the 2 bracket type things off of the bench and then drilling holes into them, and then puting them both onto 1 captin's chair.
Problems are that i can only thread the nut onto 1 bolt per bracket. The benches sliding device cant move past the closer bolt and nut of the chair. So if i slide the device all the way to the front to put on 1 nut, i cant slide it all the way back to put 1 in the front.
Also i would have to drill 4 new holes per chair for the old brackets. Using the exiesting 2 holes on each side place the chair to far to the center. In doing this im not sure if the brackets would lay flat because the cab floor is full of mountains and valleys.
The 2nd way i could do this is to use the brackets that i pulled with the seats from a conversion van.
Problems are again 4 Holes per chair and much different spacing. The brackets are ment for a flat floor and again the trucks floor is full of rises and drop offs. Also the seats sit too high and leans to far back, again due to the floor's humps.
I think if i can get the right mesurements i can cut the Van brackets so the they will be lower and with less lean to them. But i will lose the bolt holes in them, so i could try to bolt some little L shaped peices onto whats left of the van bracket and then bolt those to the floor.
I know this is realy long and with poor spelling and wording but if any one has suggestions let me know.
Old 04-29-2009, 01:53 PM
Old 04-29-2009, 02:33 PM
2001LSV65SPD's Avatar
2001LSV65SPD 2001LSV65SPD is offline
2001LSV65SPD is starting off with a positive reputation.
I just acquired buckets and a counsel from a 2001 F250 (to replace the bench). I plan on installing them this weekend. From the looks of things and the measurements taken I believe I will be able to use one of the existing bolt holes from each side. I will post pics and anything that may help as soon as I am done.
Seat for 1953 F100 stang4man 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-07-2017 03:38 PM
Seats jonesa49f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 05-02-2014 01:24 PM
What year seat will fit? uh60 1987 - 1996 F150 & Larger F-Series Trucks 5 11-16-2013 01:39 AM
Seat recovering PWILDER 2004 - 2008 F150 0 05-31-2011 04:14 PM
Seat belt beeping??? xluckyxbulletsx 6.0L Power Stroke Diesel 5 08-13-2009 02:35 PM
Tags
1994, bench, f150, seat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
