What size tires
What size tires
Hey guys, its been awhile. Anyways my truck is set to be completed all new paint and stuff by the end of may. I need to buy tires and the ones that were on it were 33's do u guys think i could get 35's under it and more importantly do you think they will look good? I would love to lift it about 2 more inches but I have no idea on how much it is lifted now?
Heres pics with th 33's
just to double check on this because i have the same question. i have a 79 f150 and i want to know if 35"s will fit without rubbing through suspension travel. heres some pics from when i bought it...
and yea i know that the box needs some work... i'm gonna weld some bracing in it next week
they will fit, no lift needed. fitment will be fine as long as u use 15x10 rims. my truck sat nose down and they had no problem fitting under it.
to the original poster, 35's work great. plenty of room to articulate and whatnot.
Personally i like the look (and performance) of about 4-6" of space between the tire and wheelwell regardless of lift or tire size, when you have too much tire stuffed into the wheelwell then tire will hit fender before bump stop hits springs, a stock highboy can easily clear 35's and still look good, sure you can stuff 37's under there but it's gonna get pretty tight, you can put 33's under most other dentside 4x4's without any problem but 35's are just stuffing the wheelwell too much without at least a 2" lift.
