Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 04-23-2009, 09:56 PM
86bigred's Avatar
86bigred 86bigred is offline
part time
86bigred is starting off with a positive reputation.
ok thanks.
__________________
81 f150 302 4 sp od daily driver
86 f250 460 t19 4x4
85 f150 300 t18 4x4
89 ford tempo
83 ranger 2.3 4sp
http://s469.photobucket.com/albums/rr57/86bigred/
  #17 (permalink)
Old 04-23-2009, 10:05 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
I'll make another suggestion for a FAQ - the key locks on the steering wheel
column are known to stick/lose their springiness and don't always fully get to
the RUN position after having been in START, this results in electrical stuff
not working. It's in the archives (many times) somewhere....
EDIT: There is also a pot metal piece that actuates the rod running the
length of the column that is known to break.
  #18 (permalink)
Old 04-23-2009, 10:13 PM
86bigred's Avatar
part time
Post
heres another one used alot.
Dictionary of Automotive Terms A-Z
cool thanks.
__________________
86 f250 460 t19 4x4
85 f150 300 t18 4x4
89 ford tempo
83 ranger 2.3 4sp
  #19 (permalink)
Old 04-24-2009, 02:59 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 is gaining momentum as a positive member of FTE. Dean88 is gaining momentum as a positive member of FTE.
Post
I think says me there should be the link for the IDI page in the sticky to go ahead and direct new comers with the 6.9 and its problems to the IDI forum and the gurus of it.
www.ford-trucks.com/forums/forum117
__________________
1992 F250 351W E4OD 3.55 Sterling
1988 F250 7.3 C6/underoverdrive 4.10 D70
1980 F100 300 3spd 2.73
1987 F150 302 T18 4.10 (RIP)
American by birth, Southern by the grace of God, Libertarian by choice!!!
  #20 (permalink)
Old 04-24-2009, 04:53 PM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
rmalottwtes30 is starting off with a positive reputation.
How aobut posting the thread I made about making an A pillar gauge? I will search for the link later..
__________________
Ryan
1985 F-250
6.9 IDI
  #21 (permalink)
Old 04-24-2009, 05:31 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Yes, Please do find that.
Thank you.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #22 (permalink)
Old 04-24-2009, 06:08 PM
86bigred's Avatar
part time
Post
here's how you get it in rmalottwtes30 you have to post the link.i posted it for ya.
A Pillar Gauge Pod
__________________
86 f250 460 t19 4x4
85 f150 300 t18 4x4
89 ford tempo
83 ranger 2.3 4sp
  #23 (permalink)
Old 04-24-2009, 06:23 PM
86bigred's Avatar
part time
Franklin2 we need all those neat and very useful diagrams you have for these links.PLEASE
__________________
86 f250 460 t19 4x4
85 f150 300 t18 4x4
89 ford tempo
83 ranger 2.3 4sp
  #24 (permalink)
Old 04-24-2009, 08:17 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all
Post
ALTERNATOR WIRING
Here's a simplified alternator wiring for a truck that has a external regulator, and gauges in the dash.
http://www.ford-trucks.com/user_gall...oid=16603&.jpg
Here's a simplified alternator wiring for a truck that has a external regulator, no gauges but has idiot lights in the dash.
http://www.ford-trucks.com/user_gall...oid=28796&.jpg
If you have a alternator with a internal regulator, here's a diagram.
http://www.ford-trucks.com/user_gall...oid=28511&.jpg
TOGGLE SWITCH CONVERSIONS
If you are making a truck for off-roading, or changing your dash around to toggle switches, here's how you can make your wipers work, low speed only.
http://www.ford-trucks.com/user_gall...oid=44991&.jpg
If you are making a truck for off-road or changing your dash around to toggle switches, here's how you can make your turnsignals work with a toggle switch.
http://www.ford-trucks.com/user_gall...id=112386&.jpg
Here's how to wire a toggle switch for a power window.
http://www.ford-trucks.com/user_gall...id=117572&.jpg
GENERAL WIRING 80-86
Here's the special wiring for the fuel pumps that most 460 engined trucks had.
http://www.ford-trucks.com/user_gall...id=182593&.jpg
If you keyswitch doesn't seem to go far enough to make the engine turn over, here's a picture of the tilt steering column, and piece #14 that always breaks.
http://www.ford-trucks.com/user_gall...id=208709&.jpg
If you have a 80-86 truck that has a computer ignition, and you want to convert it to the duraspark II system, here's a diagram. You will need to get a duraspark II distributor and module box with the harness.
http://www.ford-trucks.com/user_gall...oid=30751&.jpg
Here's how to test for a drain in the electrical system.
http://www.ford-trucks.com/user_gall...oid=33968&.jpg
Here's the fuse box diagram for the 80-86 trucks. Sorry it's a little hard to read.
http://www.ford-trucks.com/user_gall...oid=54275&.jpg
MECHANICAL DIAGRAMS
Here's a good way to tell if you have a 302 or a 351w engine which both have 6 bolts per valve cover. If you have 8 bolts per valve cover you have a 351m or a 400.
http://www.ford-trucks.com/user_gall...oid=14763&.jpg
Here's what to look out for when assembling the locknuts on a 4x4 front hub.
http://www.ford-trucks.com/user_gall...oid=16705&.jpg
This is one way to try and get the wiper knob off. It's not easy no matter what you do.
http://www.ford-trucks.com/user_gall...oid=24489&.jpg
Here's how I mark a distributor to make sure I get it back in exactly how I removed it, making sure I never turn the engine during the process.
http://www.ford-trucks.com/user_gall...id=154063&.jpg
Here's a auto tranny identifier.
http://www.ford-trucks.com/user_gall...id=169485&.jpg
__________________
Dave F
1989 F250 XLT Diesel
  #25 (permalink)
Old 04-24-2009, 10:43 PM
86bigred's Avatar
part time
your the best.those will be real helpfull
__________________
86 f250 460 t19 4x4
85 f150 300 t18 4x4
89 ford tempo
83 ranger 2.3 4sp
  #26 (permalink)
Old 04-25-2009, 12:50 AM
Post
Hi All,
Ok, We finally got a sticky, Someone has to manage that sticky, At the moment horsepuller (Scott) has stepped up to the plate and is giving his time to manage it, how about us that ask him to add stuff to the sticky make it easier for him to do so by cleaning up the links with a description as in the following...
I mean no offense to anyone, just suggesting we help our Sticky manager.
I used Sycostang #11 post as an example. (Not picking on you, just an example)
Text Example of the first 5spd swap (URL tags are broke intentionally):
[U_RL="http://www.ford-trucks.com/forums/785923-5spd-installation.html"]1984 F150 with M5R Swap[/U_RL]
And what it will look like:
Good 5spd swap threads.
1984 F250 4x4 460 with ZF5 Swap
Front clip swap.
1985 F250 with 1996 Front Clip
1985 F250 with 1994 Front Clip
Front Clip Swap General Information
Tailgate swap.
Tailgate Swap General Information
Headlight relay upgrade.
Whiter Whites, Brighter Brights Headlight Relay Conversion
White face gauges.
1985 White Faced Gauges
-Enjoy
fh : )_~
__________________
  #27 (permalink)
Old 04-25-2009, 04:22 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation
Thank you all for the work you're doing digging up these threads and posting url's. As you can see, the sticky is starting to take shape.
Good job, guys!
__________________
Scott
Forum Guidelines
  #28 (permalink)
Old 04-25-2009, 11:56 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
Thats a great idea, I would have done it that way but forgot how a long time ago.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #29 (permalink)
Old 04-25-2009, 05:48 PM
80-86 Dash Pads - What Fits
-Enjoy
fh : )_~
__________________
  #30 (permalink)
Old 04-25-2009, 11:40 PM
Franklin2's Avatar
So if I start out with the url that the board automatically generates, I need to add the quotes, and the one bracket in the middle, and then the text to the right correct? Is there a automated way to do this, or you only do it by typing it in?
__________________
Dave F
Tags
70hd , 8x170 , 8x65 , capacities , dana
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
