Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
Closed Thread
  #1 (permalink)
Old 04-23-2009, 03:50 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation
Post '80-'86 Tech Tips, Tricks and Projects:
Welcome to FTE and thanks for joining us in the '80-'86 forum.
Forum Etiquette
Please make sure you have read and understand the Forum Guidelines. Be patient waiting for a reply to your topic. Please do not post duplicates of the same topic. If you have multiple questions on several different components of your truck, please post them as separate topics rather than shotgunning them in the same thread.
Help others to help you. Give as much information about your truck as possible related to the topic. If replys were helpful or even if they weren't, post back and let everyone know if you found useful information or still need help. Topics with solutions to common and uncommon problems are helpful to others who are browsing and adds to our information base.
Take the time to thank those who help you. Other's give freely of their time, knowledge and personal experience. Please show them courtesy by acknowledging their efforts to help you. Moderator's are volunteers and do not monitor the site contunuosly. If you see something that you think doesn't belong, please use the post report feature.
INDEX
__________________
Scott
Forum Guidelines
  #3 (permalink)
Old 04-27-2009, 02:48 PM
Gauges, Instrumentation and Controls
A Pillar Gauge Pod
White Face Gauges
Speedometer Calibration
Tach is All Caddywhompus: Repair
__________________
Scott
Forum Guidelines
  #4 (permalink)
Old 04-27-2009, 03:05 PM
Electrical: Alternator, Wiring and Lighting
Whiter Whites, Brighter Brights Headlight Relay Conversion
2G to 3G Alternator Upgrade
3G Alternator Install with Pictures
ALTERNATOR WIRING
Here's a simplified alternator wiring for a truck that has a external regulator, and gauges in the dash.
Here's a simplified alternator wiring for a truck that has a external regulator, no gauges but has idiot lights in the dash.
If you have a alternator with a internal regulator, here's a diagram.
TOGGLE SWITCH CONVERSIONS
If you are making a truck for off-roading, or changing your dash around to toggle switches, here's how you can make your wipers work, low speed only.
If you are making a truck for off-road or changing your dash around to toggle switches, here's how you can make your turnsignals work with a toggle switch.
Here's how to wire a toggle switch for a power window.
GENERAL WIRING 80-86
How to Wire in Stock Factory Options.
Here's the special wiring for the fuel pumps that most 460 engined trucks had.
If you keyswitch doesn't seem to go far enough to make the engine turn over, here's a picture of the tilt steering column, and piece #14 that always breaks.
If you have a 80-86 truck that has a computer ignition, and you want to convert it to the duraspark II system, here's a diagram. You will need to get a duraspark II distributor and module box with the harness.
Here's how to test for a drain in the electrical system.
Here's the fuse box diagram for the 80-86 trucks. Sorry it's a little hard to read.
__________________
Scott
Forum Guidelines
  #5 (permalink)
Old 04-27-2009, 03:14 PM
Ignition and EEC (Electronic Engine Control)
Coil Problem. Need Help.
EEC IV Codes
Smog and EEC-III Questions
__________________
Scott
Forum Guidelines
  #6 (permalink)
Old 04-27-2009, 03:22 PM
Carburetion and Fuel Injection
Ford Fuel Injection 3G Install Tech (off site)
Motorcraft 2150 2V Carburetorm (off site)
__________________
Scott
Forum Guidelines
  #7 (permalink)
Old 04-27-2009, 03:34 PM
Transmission, Clutch, Axle and Wheels
Good 5spd swap threads
1984 F150 with M5R Swap
1984 F250 4x4 460 with ZF5 Swap
Ford Flywheels and Flexplates (off site)
Wheels
Wheel Technical Information (off site)
Gear Ratio/Tire Size Calculator
Axle
TTB frame bushing replacement
Dana axle service manuals, PDF.
Axle Identification Chart
__________________
Scott
Forum Guidelines
  #8 (permalink)
Old 04-27-2009, 03:38 PM
Engine and Performance
Visual differenced between 351C and 351W.
Adjusting hydraulic valves.
__________________
Scott
Forum Guidelines
  #9 (permalink)
Old 04-27-2009, 03:41 PM
Chassis, Body, Trim and Exterior
Front clip swap
1985 F250 with 1996 Front Clip
1985 F250 with 1994 Front Clip
Front Clip Swap General Information
Tailgate Replacement
Tail Light Swap
Door Hinge Replacement
'68-'86 Explorer Trim
Rear window replacement:
Changing Rear Window
Rear Window Replacement
Chrome and trim:
Cleaning rust off of chrome with Coke
__________________
Scott
Forum Guidelines
  #10 (permalink)
Old 04-27-2009, 03:53 PM
Diesel Tech
FTE forum: Pre-Power Stroke Diesel 7.3L IDI & 6.9L
Glow Plug Testing Procedure.
Injector Return Line Replacement Procedure
Electrical Connector Failures
6.9 IDI Block casting (is your 6.9 prone to cracking by the block heater?)
__________________
Scott
Forum Guidelines
  #12 (permalink)
Old 04-27-2009, 07:27 PM
Oil and Lubrication
Low ZDDP Oils and Flat Tappet Cams
__________________
Scott
Forum Guidelines
  #13 (permalink)
Old 04-29-2009, 11:31 AM
Books and Resources
Ford Truck Computer Wallpaper
Ford F-100/F-150 Pickup 1953-1996
Ford Racing Parts Catalog. 17.7 MB Adobe file.
Chilton Library: Automotive Repair Information for Do-It-Yourself (DIY) People
__________________
Scott
Forum Guidelines
  #14 (permalink)
Old 06-17-2009, 10:02 PM
Interior
How to fill in the speaker holes and cracks in your dash.
Extreme Makeover: Em's Cab Edition
__________________
Scott
Forum Guidelines
  #15 (permalink)
Old 06-21-2009, 11:35 PM
Heater and Air Conditioning
A/C Conversion R12 to 134
__________________
Scott
Forum Guidelines
Closed Thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
