ultracomp tune tearing up trans????????
on my second stock trans. y is it making them slip. guess i going to may to build a suncoast trans. it is slipping or like the converter isnt locking up?from 3 t0 5 shift. why would it do this? trans i put in only had 45,000 miles on it. could it be the converter?
on
I will say this, the suncoast kit allows for you to use cheaper tranny fluid. I wouldn't.
i 'm just wondering if anyone else has had this problem. hate to rebuild tran and it happens again.tex what tune r u running with the Phalanx. to they have a ultracomp tune yet. or do u think the hybrid is faster than the ultra tune on the sct? the hybrid on my truck is slow compared to thr ultra.u think the kit for 8 or the kit for 12 from suncoast?
on
I have the 8 kit. Make sure you get the billet input shaft as well. And put the clearance at .048(tight as it will go). You'll know what I'm talking about when you get the instructions. Give yourself about a month lead time for the custom converter.
on
You'll want to get their performance converter then and just a warning, it will run hotter then stock. Mine does and I have them build it closer to stock because I do heavy hauling. You'll need to get some new tunes though to help it out, otherwise it'll shift almighty rough.
on
No, your 3-5 issues are not converter based. I would be willing to bet your intermediate clutch is going or is bad.
Fraid not. I don't even think he has the software anymore to do that. Proprietary and all that I think.
