1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Slack in steering
Old 04-22-2009, 04:11 PM
Baja 89's Avatar
Baja 89
Baja 89 is offline
Slack in steering
2000 F250 4x4 V10, all new ball joints, but has pay in steering box, is there any way to adjust or will I have to replace?
Thanks
Old 04-22-2009, 04:20 PM
eightrac's Avatar
eightrac
eightrac is offline
You can try to adjust the bearing but usually, it doesn't make much of a difference. I'm in the same boat right now.
Old 04-22-2009, 08:17 PM
cpdorroh's Avatar
cpdorroh
cpdorroh is offline
Let me guess..... going down the highway or interstate you have about a 1-2 inches of slack in the wheel. Had the same problem on my '04, my dad had the same problem on his 2000, and another friend of mine had that problem on his 2000. All 3 started having issues between 90k-120k. Tightening up the adjusting screw on top of the steering box cured the problem on all 3 trucks. Just loosen the lock nut, and tighten the adjusting screw until you meet a lot of resistence, then back it out 3/4 of a turn and tighten the lock nut. It's important to hold the lock nut in place with a wrench while tightening the adjusting screw. Likewise, hold the adjusting screw in place with an allen wrench while tightening the lock nut.
Old 04-22-2009, 08:48 PM
Pinky Demon's Avatar
Pinky Demon
Pinky Demon is offline
That's very interesting. My truck has some slack too, I just got ball joints, front sway bar end links, and a total front end alignment. Still a little play. I'll have to look into this. BTW, mine has roughly 66,000 mi.
Old 04-23-2009, 01:43 PM
Baja 89's Avatar
Baja 89
Baja 89 is offline
Thanks for the info, I will give it a try.
WidowMaker13
04-08-2015 11:22 AM
351Cleveland C4
12-18-2014 08:06 PM
SuperDuty93
04-23-2012 11:24 PM
Walston
18
11-15-2010 04:52 AM
kmusmc
15
04-29-2005 08:45 AM
Quick Reply: Slack in steering
