Differences Between E7 and E8 Heads
Old 04-22-2009, 01:34 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
FordTrucksKickGM is offline
Ive got an 89 F-250 with a 460 and its either got a bad head gasket or bad head. Im not positive but I think its got the fuelie E7 heads. Ive got a set of E8 heads which I believe were some sort of motor home specific heads. If one of the E7 heads are bad can I use an E8 head in its place?
Old 04-24-2009, 12:32 PM
mcdonaldm's Avatar
mcdonaldm
mcdonaldm is offline
are you sure it is an E8 not a F3 head?
the F3 and E7 should be identical heads.
if it is a E8 head and is from a 88 motorhome, it might be a carb head as some motorhomes still used carbs for a couple of years after the trucks went to efi. if so then it will not interchange with the fuelie heads as the ports are different.
rgds
Mike
Old 04-24-2009, 01:52 PM
FordTrucksKickGM
Ya they are E8 stamped on the lifter valley side of the head. I did some research once before to find what they were but couldnt remember where I found the info. The motor did have a carb on it before I tore it down. So I suppose they are not interchangeable for that 89 truck.
Old 04-24-2009, 04:19 PM
mcdonaldm's Avatar
mcdonaldm
if they came off a carb'd engine then they will definetely not interchange with the fuelie heads. need to find a fuelie head.
rgds
Mike
Old 04-25-2009, 08:05 AM
C-Leigh Racing's Avatar
C-Leigh Racing
C-Leigh Racing is offline
I have an 88 model M/H which has a 87 model 460 engine & trans, but the heads were E6TE's making them 86 models.
Yours being E8's & knowing for sure they are carbed heads but you need EFI heads, might be you could go to 460.com & see if anybody over there has an EFI set of heads & might want to trade.
Normaly though, those guys are looking the D3 heads because of not having the air hole in the port & a little easier to port, but still, might be somebody wanting to get rid of a fuelie set.
Neil
Old 04-28-2009, 01:14 PM
The "Mad Porter"'s Avatar
The "Mad Porter"
The "Mad Porter" is offline
E6TE and the motorhome carb specific E8TE castings are the early style non EFI castings. They are later D3's.
Old 04-28-2009, 02:25 PM
FordTrucksKickGM
Hey Scott, its nice to see ya visiting the truck guys. You musta gotten bored while 460ford is down. Im BigBlockMark over there and Ive bought stuff ya.
Old 04-28-2009, 02:50 PM
The "Mad Porter"
Partially...
I am getting a bunch of client chatter about my name on this board so I felt it a good idea to check it out...
Old 04-28-2009, 03:00 PM
C-Leigh Racing
Hey Mad, who is it own that site anyways, I've not been there long enough to figure it out, but ol chilly & Evans seem to be might strong & wheres monsterbaby.
Neil
Old 04-28-2009, 03:34 PM
The "Mad Porter"
Smile
Neil
Chilly...
Old 08-16-2022, 11:48 PM
black & blue 78/9's Avatar
black & blue 78/9
black & blue 78/9 is offline
Learning Heads
Hi. I'm learning Heads and engines. I believe I destroyed my #5 piston on my 400 in my 79scab 4x4.
I have a 79 E series 460 in storage with what I believe to be under 100k miles Based on plug wires, vac hoses and emission lines/ hoses still being date coded to 79. So I'm learning about heads and you guys talk about different date coded on the heads. Question,..."Where are the date codes on the heads"? I know the block code is above the starter but no clue on the heads.
Thanks for the help, Chris
Old 08-18-2022, 11:43 AM
The "Mad Porter"
Chris,
Shoot me a FB message or Email me for help.
I rarely visit here anymore.
Scotty Jay / Parkland - RHP
Eh1992xlt
08-03-2017 10:00 PM
Xwarrior86
21
02-27-2017 08:49 AM
Mudsport96
18
08-25-2015 04:38 AM
davidmoss1992
04-12-2012 09:41 PM
cujo8
05-19-2006 05:12 PM
Quick Reply: Differences Between E7 and E8 Heads
