Magnesol use
Magnesol use
Hey Don.
I ran out of Magnesol and need to order more. I read on Utah Biodiesel that they don't like Magnesol and recommend using towers and Thermax and Eco2 Pure. What's your take on that? Are you still using Magnesol?
Incidently, I still am not recovering methanol to speak of. I vaporized 40 gals of bio and 10 gals of glycerol and only recovered about a cup of methanol. Heated to 180, vaporized, and ran it through a condensor. Oh well, some day I may figure out why it isn't working.
One more question. After SLOWLY mixing the magnesol, letting settle,and skimming the BD off the top, I leave the Magnesol in the barrel and add more to it fot the next batch. I finally scrape the old Magnesol off the bottom after about six batches. Any problem with that? I hand stir the old stuff into the new stuff and mix.
I see Magnesol is almost $100 for a 45 lb bag. Is that right?
Hope you are well. How is the trailer coming along?
Regards, Tom
Regards, Tom
Saw that on the newsletter too. I wonder if they are using the wrong pumps and an having it ground up in the pump then having problems filtering. I really was pleased with the results of my Magnesol experiment... I used a 25/10/1 combination of bag filters. What the opinion on these other products?
Hey Don.
Regards, Tom
Regards, Tom
Most problems people have with Magnesol is because most of them are using an appleseed style of processor and are pumping the Magnesol "mix" through their centrifugal pump. A centrifugal pump will not give good results, so they "bad-mouth" the Magnesol, not their pump! I still use Magnesol, and have tried the "resins" but don't like how slooooowly they work. Yes you can leave the used Magnesol in your tank for several batches. The price of Magnesol is around $100/bag, but the results, and speed of cleaning makes it worthwhile in my opinion. My new processing trailer is finished, and I'm acquiring the rest of the "parts" to build the rest of the system. I have 5 farms under contract for the new Co-Op, the canola is growing, and we should start producing bio about Nov! My new service company is is growing and I've had to hire a couple of mechanics to keep up with the growing demand. I've been off-line for about a week because I pulled my back muscles last weekend, and my Dr can't see me until this afternoon.................Winter was tooooo long, sure glad spring is finally here!
I will probably do the same thing for now. Need to order Magnesol...
Too busy to reply to you and Phydeaux right now. Will reply when I have more time to "hash it over". Thanks to both of you for your interest in my condensor problem.
Tom
Just wondering, is Magnesol hydroscopic enought that once I open the bag, it needs to be sealed back up in a garbage bag or something? how do you guys store it?
thanks
Just got my order in. The response that I got from Fryerpower when I sent him an email is that he no longer does 45 lb bags.
thanks
thanks
Be sure to MIX SLOWLY.
Tom
Thanks Tom!
I leave mine in the original bag and box it came in and just roll up the end when I get some out. I use a plastic coffee can and scoop out what I need into a plastic zip lok bag.I live in a very humid climate and never had a problem. I leave it in the garage. Be careful and do not breathe the dust when you are handling it.
Tom
Tom
