power steering pulley
Old 04-21-2009, 05:49 PM
santaak's Avatar
santaak
santaak is offline
I have a 78 F 150 4X4 300 six. I need a power steering pulley, the bad one I have is marked as this; EOTC-3D673-BA with the ford marking. Anyone know where I can locate one.
Thanks
Old 04-21-2009, 07:58 PM
MotherTruckinMarine's Avatar
MotherTruckinMarine
MotherTruckinMarine is offline
Junkyard is about the only place. Luckily, you arent limited to just 73-79 ford trucks. I pulled one off a 78 LTD with a 400M. Just take your old pulley and a pulley puller with you.
Old 04-21-2009, 09:42 PM
santaak's Avatar
santaak
santaak is offline
Cool
Thanks. The problem is I live in rural Alaska and there are no junk yards with in 200 miles of here. I found on locally off a early 80s v8, it looked like it would fit but the offset was wrong and the belt would not line up.
Old 04-22-2009, 12:35 AM
Alvin in AZ's Avatar
Alvin in AZ
Alvin in AZ is offline
Originally Posted by santaak
...found on locally off a early 80s v8, it looked like it would
Not even with a little fudging of where you set the pulley on the shaft? :/
It don't have to look like it's off the dealer's floor. ;)
But yeah, that sucks about the wrecking yard situation, my best advice
involves memorizing what yours looks like from the side (noticing offset
in fraction of an inch) and just go looking for one close enough. Mine was
a quarter inch and found my spare on a 400(?) in a big ol' Ford car too.
I did quite a bit of looking before I found one and of course, had to buy
the whole pump to get it.
I have a new water pump on the shelf and when that sucker is on my
360FE I have to shim one of the rear power steering pump studs so
the pulley is square with everything. I use two layers of street-sweeper
broom-straw.
Alvin in AZ
Old 05-01-2014, 07:11 AM
tml61747's Avatar
tml61747
tml61747 is offline
in need of this pulley also!!!!!!!!!!
EOTC-3D673 BA 1986 FORD F250 4.9L INLINE 6. NEED PULLEY WITH PUMP IF POSSABLE! THANKS TOM
Old 05-01-2014, 07:33 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by tml61747
EOTC-3D673 BA 1986 FORD F250 4.9L INLINE 6. NEED PULLEY WITH PUMP IF POSSIBLE!
Please type further posts in the 1980/86 forum, this is the 1973/79 forum.
Pulley does not come with the pump, it was sold by itself and is a Ford dealer part only. The pump can be purchased from any auto parts store.
EOTZ-3A733-H .. P/S Pulley / Marked: EOTC-3D673-BA / Obsolete
Last MSRP: $110.40 - Dealer net cost: $66.24.
Applications: 1980/86 F150/250 4WD & Bronco 4.9L without A/C.
No Ford dealer or obsolete parts vendor has any.
Old 05-01-2014, 07:51 AM
raven3's Avatar
raven3
raven3 is offline
Could machine a billet aluminum pulley, as an option.
Old 05-01-2014, 01:49 PM
61steven's Avatar
61steven
61steven is offline
I had one heck of a time finding a pulley for my 400! All of the local parts stores said the pulley was discontinued by the one manufacture they bought from. I ended up buying an aluminum one from Amazon.
Old 05-01-2014, 09:03 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
Jeff's Bronco Graveyard has 'em for the 400
Old 05-01-2014, 11:02 PM
Red Mercury's Avatar
Red Mercury
Red Mercury is offline
Thanks
You might know this already, but the pulley you currently have is not for a 78 F150. It is from a truck in the 80's. I think that is why ND was trying to direct you to the 80-86 forum.
Ford used a lot of different PS pulleys. I usually start by getting the correct part number and then start doing internet searches. I have had pretty good luck finding correct PS pump pulleys on ebay. Searching by only the engine size and year of the truck doesn't always get the right pulley. Part numbers do work better.
Old 05-01-2014, 11:41 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
NumberDummy, post #6, was quoting post #5....
You are making a confusing thread, even more confusinger
Old 05-01-2014, 11:52 PM
Red Mercury
Jklnhyd, you are correct. I accidentally skipped over post #5. My bad & I apologize for the confusion.
The fact remains that the original poster may or may not be aware that the pulley on his 78 F150 is not the original one for his truck. Based on experience, it isn't much fun guessing which truck should have which pulley. It amazes me how many different pulleys there are for these trucks.
Old 05-02-2014, 12:04 AM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
No harm done, lol. Feel free to read most of my posts with tongue in cheek, and a bit of dry humor.
The original poster is 5ish years older, btw.
And the pulleys vary that much? I had no idea. Maybe this thread could be useful, next time it is necroposted, if you could share some of what you have discovered.👍
Old 05-03-2014, 12:35 AM
Red Mercury
Jklnhyd. Oh man, I am I ever loosing it. I never even realized how old the original post was and I was commenting like it was a new post. If I could just find somebody else to blame for my stupidity.......no such luck--this one's all mine.
Regarding different power steering pump pulleys on Ford trucks. I took a look through the parts manual and it lists 7 different pulleys for the 73-79 F100-F350 trucks with 300 engines. Some change from year to year, some for AC equipped trucks, some specific to F250's only, etc. Physically, I don't know what the difference is between each pulley. I first ran into this power steering pulley nightmare when searching for a power steering pulley for a 390 a few years back. I ran across pulleys for 360/390 engines from different years and some would not work at all on my 390. It is possible to find a pulley that works on a truck in the junkyard and sometimes they are a perfect match. Sometimes they sort of fit and you do funny things like having to position it abnormally on the pump shaft to get the pulley to line up. I do original restorations on my trucks so I am fussy about having the right pulley and everything that goes with it.
Old 05-03-2014, 09:25 AM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
I recently replaced my ps pulley (1979 f250 4x4 w/AC) and the only place i found it was JBG. And it only had one listed for 77-79 351m-400, so i was a bit anxious when ordering it.
I got it, and it fit perfectly.
My original pulley had spun out, and in hindsight, was way too loose when i replaced my ps pump. I would be leary of a junkyard pulley
Black Ford XLT
02-11-2017 06:45 PM
gary's1950F1
11-21-2016 11:11 PM
seventy2ndst
11-18-2015 05:50 PM
ronspolv
WTB - Parts & other
05-11-2015 06:38 PM
Mark-I6
05-13-2006 05:10 PM
Quick Reply: power steering pulley
