Fuel Selector Valve?
Now at the expense of sounding ingorant. how do you determine which line is the return line and which is the send line without pulling the pump?
Thanks Number, but after some research, my truck doesn't actually use a selector valve
And...btw...I knew the part number the sec I read the post, as I've listed it here before...several times...for others that have asked about it.
I might be wrong but from years of crawling under these things and looking at fuel lines I thought I saw something that looked like a fuel relay or switching device of some sort-should be something to switch between tanks
Sorry, not trying to cause any arguments here, but I followed the fuel lines from the tanks all the way up to the engine and no fuel selector valve anywhere on the frame, so this truck apparently doesn't have one. I spoke to the Ford dealership again and they concurred that certain 1990 F-150's did not have a fuel selector valve. They did say that the check valve part number can be looked up via the recall number 93s68 and the cost for the check valve....hold on for this... is $99 each. So for now, since I am un-employed at the moment, am going to put the bed back on and just switch between tanks to keep the fuel level correct until I can afford to replace the fuel pumps/FDMs. <sigh>
Thanks for the help everyone.
Mike
Mike
If thats the case, why is it listed in the 1990/2002 Ford Light Truck Parts Catalog for 1990/93's?
I haven't a clue. Have you seen one on a 90-93 truck, or just in the 'fische?
I have to honestly say in the fiche, because while I may have seen the valves years ago...it has been 12 years ago.
And we've had this discussion before too. Maybe some trucks used the external switching valve, but to give someone a part number and tell them "this is what you need" without any regard to what is actually used on their truck could cause someone to waste their money.
This valve also fits earlier models.
And this time...I didn't say "this is the one you need."
Did you happen to contact FTE sponsor FTEpartsguy.com for assistance in locating the correct part?
This is Ed Olson, parts manager @ PARR FORD in Bremerton. Ed will assist you, there's no charge, no obligation to buy anything.
The part he was looking for is this outside check valve for the pressure line:
http://i54.photobucket.com/albums/g9...heckValve2.jpg
http://i54.photobucket.com/albums/g9...heckValve1.jpg
It was used in the 1990-1993 ford truck recall some f-series trucks had bad Fuel pressure regulators that made the high pressure check valve in the Fuel Delivery Module go bad or so said Ford in the recall. They used the above check valves so they did not have to replace the FDM. They also replaced the FPR in the recall.
The Recall:
https://www.ford-trucks.com/recalls/...y-1993/t-28401
FDM:
http://i54.photobucket.com/albums/g9...yAssembly2.gif
The Mechanical fuel selector valve/reservoir was last used on the 1990 Ford Truck and 1991 E-series vans.
http://i54.photobucket.com/albums/g9...ectorvalve.jpg
The valve that lisagoud is talking about above is the electrical fuel selector valve and was used on most Diesel truck in the 80's and 90's.
http://i54.photobucket.com/albums/g9...tfuelvalve.jpg
The Recall:
FDM:
#28
#29
i have a 93 f150 and im wondering where i put the inline fuel check valve? i took out the front tank to run straight pipes, and i am running only on the rear tank. when i try to start it it takes a while for the fuel to travel through the lines and reach the engine? help?
#30
Don't go crazy looking for the valve. 1990 was the first year for the high pressure in-tank pumps, which eliminated the external switching valve. The switching mechanism is located within each tank, and open or close depending on which fuel pump is running. If fuel is transferring from one tank to the other, replace the fuel delivery module in the tank where the fuel is going.
tnab1970
04-21-2017 08:11 AM
nova801428
12-28-2016 11:25 AM
newrevnorton
10-30-2016 01:25 PM
KHflatbed
10-12-2016 09:58 PM
