You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Does anyone in the Tulsa/Owasso area know carburetors? If so are you willing to teach me how to adjust mine? I have a Holly model 80457s on my Thunderbird. It's rated at 600cfm's which is very close to the 595cfm's that the original Autolite had. I can't get a smooth idle when the engine is cold. When warmed up, it idles pretty smooth. I think i have so far out of adjustment, I don't know what to do.
__________________
Mike B
1969 ForDor Thunderbird
2006 Dodge Charger (wifes car)
2000 Ranger Regular cab
2.5L with A/C backed up by the 5 speed manual, 2WD.
159,000+ on the clock.
sounds like you need to adjust the idle mixture screws, they are on the side of the front meatering block. There is one on each side adjust them the same on each side.
Thanks,
Is that like turn them all the way in then back out 2 1/2 turns. Then either in or out to obtain a smooth idle? Will adjusting them affect the idle rpm's?
__________________
Mike B
it will affect the rpms to a point, but u dont use them to udjust the idle, just to smooth it out, yes, 2 1/2 turns out is the best starting point for most carbs...but, its mostly only gonna be smooth when the engine is warm...thats why auto chokes where invented, cause its almost impossible to make a carbed motor run smooth when cold without a choke or throttle control to keep the rpms over 1200 until its warm...plus when cold carbs tend to "ice over" because the fast moving air freezes any water vapor inside the idle circuits of the carb, hence the reason for choke stoves (tube coming from the exhaust manifold) on stock air cleaners...at our shop the way we remedy rough running motors is to ditch the holleys, edelbrocks, carters and stock carbs, and replace them with demons.....demons need a little tuning after install, and then they run great with improved throttle response and power...but even those carbs run rough until the motor is warmed up...EFI engines have an advantage and run smoother cold because they adjust accordingly to what the sensors tell the computer...
__________________
Why is there never enough time to do it right the first time, but always enough time to do it again??
....Will work for Rep points....
