Duel Fuel Only Runs On One Fuel?
Old 11-10-2008, 03:33 PM
68f250360's Avatar
68f250360
68f250360 is offline
i have a 95 f250 4x4 7.5 running on propane or gas. due to gas prices i have been running it on propane, but now that gas has gone down i what to run it on gas but it wont switch over. i flip the switch and the thing just dies. so when the truck isnt running i turn the key on and off to "charge" the fuel system but nothing seems to work... the fuel rails are getting pressure, i check. i also check the fuel reset switch but that was fine. so i got out the test light and started to hunt down wires but i cant find the problem. i dont know if the gas went bad, i dont think so cause i added additives last time i filled up.
can someone help???
Old 11-25-2008, 03:30 AM
myv-879's Avatar
myv-879
myv-879 is offline
Possibly by not using Gas (petrol) something has dried out and is not operating. This used to happen to me in my carby 351 dual feul. I went through a feul pump and a carby kit because they dry out without feul going through them, Im now rebuilding it to run straight gas. What good does the gas (petrol) do anyway?
Old 11-25-2008, 01:52 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
Check your fuel pressure and filter also check to see if your injectors are working
I am assuming your gasoline line does not have a fuelock (solenoid) that was installed when it was converted
Old 04-24-2009, 02:31 PM
351M's Avatar
351M
351M is offline
Could it be possible that something went wrong and the injectors have been running dry for awhile and died?
krol
03-20-2008 03:54 PM
All Things Oval
03-22-2007 09:16 PM
superduty4x4
04-19-2006 07:36 PM
FreakinOldGuy
Electrical Systems/Wiring
04-09-2005 03:09 PM
CrewCabCOE
Alternative Fuels, Hybrids & Mileage
04-03-2005 01:21 PM
Quick Reply: Duel Fuel Only Runs On One Fuel?
