run wires through firewall
Old 04-20-2009, 09:41 PM
stealthsniper96's Avatar
stealthsniper96
stealthsniper96 is offline
How do you run wires through the firewall?
Old 04-20-2009, 09:51 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
It depends on what I can find that already exists and it's location. The factory used a lot of large grommets, and sometimes you can find room in them, or they are so large, you can take them out and cut another access hole beside whatever it's being used for.
If none will do, I will take and cut a decent sized hole to match the od of the rubber vacuum hose I am using, and then run the wires through vacuum hose to protect them in the sheetmetal.
Old 04-21-2009, 12:28 AM
bigshane's Avatar
bigshane
bigshane is offline
I got a great tool off the Mac tool Truck it is a punch with a hole down the center to run the wires thru. I think I saw the same tool on the Snap on truck last month
Old 04-21-2009, 04:21 AM
lew52's Avatar
lew52
lew52 is offline
I use a unibit to drill hole then use a push in grommet so the wires dont touch metal . Then when im done with the wiring i seal the grommet with silicone...Lew
06SD250
1999 to 2016 Super Duty
10-10-2010 05:17 PM
pdx02
07-13-2008 10:50 PM
cotterpin
04-16-2008 03:42 PM
volstd
1997 - 2003 F150
08-24-2005 07:32 PM
twotoneoc
1997-2006 Expedition & Navigator
10-16-2004 10:08 AM
Quick Reply: run wires through firewall
