Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
First time a track with new L
Old 10-19-2001, 06:37 PM
UnderPressure's Avatar
UnderPressure
UnderPressure is offline
I went to Atco last night for the first time with my L. I am very happy wth the results! My best et was 12.65 @ 106.8,with a 1.7 60 ft. time. My mods are upper and lower pulleys,K&N filter kit, and Diablo chip programmed by Nitrous Pete. This was also on my stock tires. This weekend the truck will get a new converter,Bassani catback exhaust, and M&H race tires and rims. Also a new program to match mods. I love this truck and can only hope for low 12s next week!!!
Old 10-22-2001, 08:30 AM
EatonSVT's Avatar
EatonSVT
EatonSVT is offline
What did you leave the line at? My 60ft was 2.1 leaving at 1200 RPMS.
Old 10-25-2001, 05:10 AM
UnderPressure
Try leaving at an idle. When the light drops-mash the pedal! If you are running F1's heat them up real good and play with your rear air psi. Hope this helps.
Old 10-25-2001, 08:52 AM
EatonSVT's Avatar
EatonSVT
EatonSVT is offline
What kind of pressure in the rear??
Old 10-26-2001, 03:55 AM
UnderPressure
The psi that worked best on my F1's was 19psi on the right and 20 psi on the left. No I didnt get to E-town this weekend,Iwas too backed up with work.
Old 12-07-2001, 02:28 PM
ryanstruck's Avatar
ryanstruck
ryanstruck is offline
How does that work? I thought you had to be running off the line at a certain rpms? If you're just idling, won't there be too much of a vaccuum to get a good launch?
Old 12-12-2001, 11:01 AM
ryanstruck's Avatar
ryanstruck
