PATS system - Ford Truck Enthusiasts Forums
PATS system
Old 04-20-2009, 01:18 PM
wcclay352 wcclay352 is offline
wcclay352 is starting off with a positive reputation.
PATS system
I have two codes running after i did the "hold the reset button" test, DTC u1147 d147 SCP invalid or missing data for vehicle security and DTC u1162 d262 missing scp message. The vehicle thinks it is being stolen and therefore will not get any feul. I know that i can tow it to a dealer and have them fix it, but is there any less expensive way to fixt this problem. Also, could someone please post a picture of the fuse and relay diagram from the manual. or send it to my email wcclay352@yahoo.com so that i can post it. Thanks.
2002 F150 5.4L FX4 - no start - appears to be a PATS problem... yosso 1997 - 2003 F150 13 09-03-2013 09:00 AM
U1262 SCP Cmmunication bus failure omanalansan 1999 - 2003 7.3L Power Stroke Diesel 5 07-28-2011 02:33 PM
lowering a 63 f100 oldgreen63 1961 - 1966 F-100 & Larger F-Series Trucks 12 02-07-2011 06:38 AM
Test Gauge Mode jmaskew 6.0L Power Stroke Diesel 3 11-21-2008 05:18 PM
Need advice for a swap on a 79 F600 Rollback deerjrky 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-06-2008 02:33 PM
Tags
2007, diagram, f150, pats, picture, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
