Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-20-2009, 12:05 PM
Bornzo Bornzo is offline
Garage is empty, add now
Bornzo is starting off with a positive reputation.
Power Liftgate Problem
I was wondering if anyone can help me. I recently purchased and programmed 2 new 5 button remotes. The issue is that the remotes will not open/close the power liftgate. All other buttons work ie: lock/unlock doors and lift gate glass. Did I do something wrong like miss a step in programming the remotes? Any help is appreciated.
Mike
__________________
Mike Bournes
2007 Expedition 5.4 Limited 4x4 Dark Grey Metallic
2006 Five Hundred AWD Limited Dark Grey Metallic
  #2 (permalink)
Old 04-20-2009, 12:40 PM
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
You're not working with one of the trucks in your sig, are you? What is this on?
Joe
__________________
2009 F450 Lariat CC 4x4
2005 Mobile Suites 36TK3
2011 MKX
  #3 (permalink)
Old 04-20-2009, 12:47 PM
Sorry forgot to update my vehicles. The vehicle in question is a 2007 Limited Expy.
__________________
Mike Bournes
  #4 (permalink)
Old 04-20-2009, 02:27 PM
On my former '07 Nav and now '08, it takes two clicks of the fob button to activate the gate--both up and down. Rear window only takes one click. Hope this is the problem?
Joe
__________________
2011 MKX
  #5 (permalink)
Old 04-20-2009, 03:24 PM
I have tried the two clicks and still does not seem to work liftgate. Everything else works except tailgate. I was wondering if I maybe programmed the remotes wrong.
__________________
Mike Bournes
  #6 (permalink)
Old 04-23-2009, 11:08 AM
Does anyone have any suggestions for the liftgate problem I am having?
__________________
Mike Bournes
  #7 (permalink)
Old 04-23-2009, 11:38 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Does it open automatically when you press the button on the dash?
Does it open automatically when you pull on the handle from the outside?
Maybe the lift arm is broken.
__________________
See ya,
Eric
  #8 (permalink)
Old 04-23-2009, 11:47 AM
function12, yes to both questions.
__________________
Mike Bournes
  #9 (permalink)
Old 04-23-2009, 12:19 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Quote:
Did you get new remotes? Did you program them yourself?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #10 (permalink)
Old 04-23-2009, 12:44 PM
The remotes are brand new and I programmed them myself. Like I said above, all the other buttons work fine except the liftgate button.
__________________
Mike Bournes
  #11 (permalink)
Old 04-23-2009, 01:15 PM
berry1234's Avatar
What happened to the original remotes? There must be a special procedure to program the lift button.
__________________
  #12 (permalink)
Old 04-23-2009, 06:19 PM
function12's Avatar
numbers on the back of my 07 fob are:
3L7T-15K601-AB
__________________
See ya,
Eric
  #13 (permalink)
Old 05-18-2009, 02:03 PM
Sorry for so long since last post. I am still having the same problem. My numbers on back of remote is 3L7T-15K601-AA. Any help is appreciated.
__________________
Mike Bournes
  #14 (permalink)
Old 05-18-2009, 04:05 PM
berry1234's Avatar
Probably dealer time. If you have less than 36K it is covered under warranty.
__________________
  #15 (permalink)
Old 05-19-2009, 01:08 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
not a Warranty issue. sounds like you have the wrong remotes man.
my 08 Expy Limited has the "3L7T-15K601-AB" code as well.
the 3L7T-15K601-AA is for a Lincoln Navi...they both have the same buttons, but the Ford version are symbols, and the "AA" have writing instead
do you have the ones that came with the vehicles? or I'm guessing you bought it used, and they weren't there?
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
Tags
09, 3l7t, 3l7t15k601aa, 3l7t15k601ab, expedition, ford, forums, liftgate, lincoln, making, navigator, noise, power, problems, program, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
