98 XLT 5.4 Need Help With Code P0354 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-19-2009, 10:12 PM
njxlt's Avatar
njxlt njxlt is offline
njxlt is starting off with a positive reputation.
Need help with a code P0354 (Ignition Coil D Primary/Secondary Circuit).
This started with a P0304 (Cylinder 4 Misfire Detected) and P0171 (System Too Lean) and I changed out the coil pack on cylinder 4 with a new one. I took the coil pack that was on 4 and put it on cylinder 1 (since this is easy to change) and still have severe hesitation. Now I am getting a P0354 code. I measured resistance on the new coil pack and the one that was in cylinder 4 and they were the same also I was curious if I would get a misfire on 1? No codes for 1 and I drove the truck around today to try and get more info. I hate to bring this to a shop since I already tackled the hard part of changing the #4 COP.
Any suggestions on where to go from here?
Old 04-20-2009, 07:53 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Your P0354 indicates that the electrical circuit for the #4 coil is open. Probably, the connector is not properly connected or you have a bent pin or the harness was stretched/pulled and is now open.
Steve
Old 04-21-2009, 04:28 PM
njxlt's Avatar
I caved in and took it to the shop down the street from me. $75 for time and they changed the spark plug in the #4 cylinder. I had already changed the coil pack on the 4 with a new one? Now all is well and running normal again.
Old 04-21-2009, 07:07 PM
A spark plug won't cause that fault code. They probably just plugged it in.
Vibration between 40-55MPH RTrud Excursion - King of SUVs 17 07-13-2015 06:37 PM
P0354 CODE Goof008 2007 - 2014 Expedition & Navigator 6 01-10-2015 03:11 PM
p0354 misfire stuemany 1999 to 2016 Super Duty 4 02-19-2013 05:34 PM
P0354 code on 2005 Escape firemech Escape & Escape Hybrid 4 12-15-2011 09:25 AM
Problems with a 98 5.4L ddwood55 Modular V8 (4.6L, 5.4L) 5 05-22-2009 06:16 PM
Tags
150, 1998, 54, 98, change, code, coil, exp, expedition, f150, ford, ignition, p0354, pack, resistance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
