Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 04-19-2009, 08:33 PM
Scott1957 Scott1957 is offline
Garage is empty, add now
Scott1957 is starting off with a positive reputation.
Exclamation Help with 1998 f-150 , will not charge.
i have a 1998 ford f150 truck, it will not charge the battery alt. is rebuilt had it checked twice battery is good 12.50 oms. Any ideas?
  #2 (permalink)
Old 04-19-2009, 09:44 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
Nice to have you here!
If the alternator checks out OK and the battery is strong are you sure you don't have a short somewhere? When the truck is running, have you checked the alt to make sure it's charging the battery? Voltage regulator?
__________________
Dan
1998 F250 LD 4X4
2004 Explorer EB 4X4
2006 KLR 685
  #3 (permalink)
Old 04-20-2009, 12:52 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
Alternator while running should be higher than 12 volts with most vehicles. 13, or more, would be more like it. Check for the output of the alternator while running (even a bit off idle) and see if you need another rebuilt Alt.
__________________
1999 F-150 XL, Extended Cab, Long bed, 4.6L, 4x4, M5OD (geez, the truck's description is just about as long as the truck itself! )
  #4 (permalink)
Old 04-20-2009, 01:24 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
When the ignition is off, 12 volts at the battery is normal. When the ignition is on but the engine is not running, battery voltage should be 11 - 12 volts. With the engine running, voltage at the battery should be 13.5 - 15.0 volts.
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #5 (permalink)
Old 04-20-2009, 01:59 PM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
No idea where you get "oms"?
Quote:
KRM02 has got the right idea. My '98 has sat for weeks & the pretty fresh battery still read 12.16 volts. When the key is switched on that dropped to 11.80 volts. Quite obviously charging, after sitting so long & on high idle, it read 14.36 volts.
IMO if you "have a short somewhere" you usually find out about it pretty quickly, especially in the large wires between alternator & battery. Shorts will ultimately pop a fuse/fusible link or smoke the wire until it burns out. More likely is a bad terminal or connection, that produces high resistance. This can fool a voltage regulator, acting like a fully charged battery.
  #6 (permalink)
Old 04-20-2009, 02:29 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
As club wagon mentioned it might be a blown fuse.
That was the prob on my Explorer when it was'nt charging. Replaced the fuse & problem solved.
Strangely enough the fuse is listed as "Generator/voltage regulator" on my 97 Explorer. Go figure. Tradition I guess.
  #7 (permalink)
Old 04-20-2009, 02:33 PM
2002 Ford F-150
Nope, Ford classifies the device as a Generator these days.
__________________
Tags
1998, 97, 98, 99, alt, alternator, battery, charge, charging, f150, ford, fuse, idle, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
