Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-19-2009, 07:14 PM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.
Where is the fuel pump weep hole
I've searched the multiple fuel in the valley threads but I can't find exactly where the fuel pump weep hole is. I think it's either the banjo bolt or the fuel pump since there is only fuel at the back of the valley. It's dry at the front of the filter bowl. I can't see any drips anywhere when I watch it running with the Y-pipe off and the little fuel pump cover off.
  #2 (permalink)
Old 04-19-2009, 07:27 PM
believer45 believer45 is offline
believer45 is starting off with a positive reputation.
If you stand at the passenger side steering tire and look in from the side you will see the filter housing and behind it the fuel pump. The weep hole leaks out just toward the front of the engine from the fuel pump mounting bolt closest to you, straight down so you cannot see it.
At least that is where mine was when it was leaking - you could watch it while the engine was running.
Dave / Believer45
__________________
'95 F250 PSD, 5-spd, 4x2, Ext Cab, 3:55 rears, 285/75 x 16 Cooper Discoverer ATR, Putco Master Boss boards, open element AIR FILTER, homebuilt REAR BUMPER, with me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160) - 280,000 miles.
  #3 (permalink)
Old 04-19-2009, 07:33 PM
Thanks,
I'll head back out with the mirror & flashlight
  #4 (permalink)
Old 04-19-2009, 07:46 PM
I can't see anything leaking right now. I had a good view under the pump on the passenger side so if it was leaking it must not be the pump.
As I said, the front of the valley is dry. It could be one of those hoses going to the pump, but I really suspect the banjo bolt. I'll try reefing on the bolt once I get a 1-1/4 wrench tomorrow.
  #5 (permalink)
Old 04-19-2009, 08:49 PM
KevinC.'s Avatar
KevinC. KevinC. is offline
KevinC. is gaining momentum as a positive member of FTE.
What year is your truck? If it is a 95 I can almost bet where it is coming from.
__________________
95 F250 XLT, 7.3 PSD, 5 Speed, Reg Cab, 2WD, 180cc Stage 1's, PHP Tuning, 3" DP to 4" straight pipe, Electric fuel pump w/ twin WIX filters, Autometer pyro, 6637, 140v IDM, CCV.
  #6 (permalink)
Old 04-19-2009, 10:16 PM
Quote:
It's one of the very first 95s to come off the line. I'm all ears.
  #7 (permalink)
Old 04-20-2009, 07:44 AM
KevinC.'s Avatar
Ok, When you are in front of your motor looking down at the fuel canister, on the very back (firewall side) bottom of the canister is your fuel filter restriction sensor. There is a plug that clips onto it. Pull the plug and start the motor, can almost guarantee that is your problem spot.
Now if it is, it is easiest to replace if you remove the turbo y-pipe, being careful not to lose the square o-ring. Now you have two options, replace it with a new one from IH or ford or plug it with a 1/8 NPT brass plug. Its only function is to tell you when the filter is clogged, will not harm anything if you leave it unplugged and plug the hole.
__________________
  #8 (permalink)
Old 04-20-2009, 09:28 AM
Thanks, I'll take a look after work.
What was different about the '95 that made it more of a problem than the '96 or '97?
  #9 (permalink)
Old 04-20-2009, 10:18 AM
Isn't the sensor at the back the water in fuel sensor?
  #10 (permalink)
Old 04-20-2009, 10:53 AM
KevinC.'s Avatar
No diff sensor. On 95 like ours it is in a diff location. In 96 they started puttin them on the FPR
__________________
  #11 (permalink)
Old 04-20-2009, 03:31 PM
Thanks,
I have an CD copy of the shop manual and it's totally devoid of any diagrams in this section.
So is the water in fuel sensor on the drivers side down low or is that the heater?
  #12 (permalink)
Old 04-20-2009, 05:30 PM
KevinC.'s Avatar
water in fuel light is on drivers fender side as is the heater. fuel filter restriction is on firewall side. There are 3 sensors in it.
__________________
  #13 (permalink)
Old 04-20-2009, 06:00 PM
BlueMule's Avatar
BlueMule BlueMule is offline
BlueMule is gaining momentum as a positive member of FTE. BlueMule is gaining momentum as a positive member of FTE.
Joe,
This is a fuel bowl from a 96. On the top,attached to the regulator is the filter restriction sensor. Below that on the side of the bowl is the fuel heater and below that is the water in fuel sensor.
Now this bowl is for a 95. The heater and water in fuel are in the same spot but the filter restriction sensor is down on the bottom of the bowl between the hoses. Also you can see the plastic strainer bowl that's below the regulator was deleted on the 96-97 canisters.
  #14 (permalink)
Old 04-20-2009, 06:34 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is gaining momentum as a positive member of FTE. Hussler is gaining momentum as a positive member of FTE.
BlueMule, tried to rep ya but got to spread it around. Maybe someone else can get it for me.
Great POST ........
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
EVBP Disconnected - Napa 6637 - FPR Shim 3" Down Pipe & CD
203
Stat - 170 K ++ Miles - Interceptor Scan Gauge
  #15 (permalink)
Old 04-20-2009, 06:59 PM
I apparently need to spread it around because I already have given it to Kevin and BlueMule.
Thanks to both of you.
The fuel bowl looks like the '95. The regulator has a switch on the side of it, so I wonder if the FPR was replaced with a later one as a "upgrade."
The sensor on the back is there and it's not wired in. I'll be pulling the whole thing soon and then maybe I can figure out where it's leaking.
Tags
1997 , 73 , 73l , 96 , 97 , diesel , f250 , f350 , f4tz9e436a , fuel , pump , seperator , start , supply , switch , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
