Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 12-20-2001, 11:34 AM
MikeS MikeS is offline
Garage is empty, add now
MikeS is starting off with a positive reputation.
Should I replace 1993 stock heads with Lightning GT-40's?
I have a 1993 F-150 ex cab with 5.0 and E4OD. I have the chance to buy some GT-40 pull-offs from a 1993 Lightning. I think I will have to use stepped head bolts because a 351 uses 1/2" bolts. Is the combustion chamber volume the same on theses 2 heads? I don't know what cc my heads are and I don't know about the GT-40's either. I believe I will gain some perfermance with them if my compression doesn't drop. I will put some headers made for my truck on them. I think the exhaust pattern is the same. I know 351 trucks get different header application but I think it is because the 351 is taller and wider so the header needs to be longer to reach the Y-pipe. I need some educated help here. Anyone have experience with a swap like this?
  #2 (permalink)
Old 12-20-2001, 01:26 PM
markus markus is offline
markus is starting off with a positive reputation.
I haven't actually done this swap, but here is some info:
http://www.corral.net/tech/powerplant/head_tech_4.html
The exhaust/headers should fit, Ford claims the GT-40s will fit stock equipment.
The only problem is like you said the head bolts for the 351Ws are 1/2 and 302s 7/16.
Markus
  #3 (permalink)
Old 12-28-2001, 11:16 AM
lghtnin351 lghtnin351 is offline
lghtnin351 is starting off with a positive reputation.
Tags
1993, 351, 40, 50, 93, cc, f150, ford, gt, gt40, heads, lightning, replacing, stock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
