IDM 100 mod w/ pics
IDM 100 mod w/ pics
Just finished it up and it still runs after I put it back in! Just wanted to post the pics on here for those of you who might want them...
Started with my stock IDM 100
Next found the blue resistor marked 6042
Removed it and carefully soldered in the new resistor
I didn't want to get the resistor too close to the circuit bored as there wasn't much space, I know others solder it closer but I wanted to stay on the safe side.
After I soldered in the new resistor I put a dab of silicone between the resistor and the green part next to it to keep it in place.
Put a bead of silicone around the cover and pressed it back together till it set up. Re-installed in the truck and it started right up! I was pretty nervous for a while though...
Havn't taken it out for a drive but will report on how it runs when I do.
Power figures I heard were about 20hp and 50 ft/lbs but it depends on the truck.
After driving it today it runs really well, great throttle response and idles smoother.
I can get a little out of it... still not much. Next step is downpipe, then TW
Just used one and a pair of small needlenose to move it a little at a time.
