IDM 100 mod w/ pics
Old 08-07-2009, 05:02 PM
79f-250custom's Avatar
79f-250custom
79f-250custom is offline
hey guys.
what kind of flux and what size solder wire did you go with? i just ordered my resistor and need to get the right wire and flux.
thanks for any info.
Mitch
  #47
Old 08-07-2009, 07:50 PM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
Originally Posted by JasWood
Is there any chance of this mod wearing out the injectors quickly?
As far as I know it doesn't. It mainly allows the injector to stay open just a tad longer letting a little more fuel in.
The Super Duty trucks have a 120v IDM... so I don't see a 140v doing anything bad to the injectors.
  #48
Old 08-07-2009, 09:29 PM
kawa's Avatar
kawa
kawa is offline
Originally Posted by 79f-250custom
hey guys.
Mitch
Don't recall the actual size...Radio Shack carry's a very thin solder that contains silver.
Use that, flows quickly and at low temp. .20 or .22 comes to mind but you will know it when you see it.
Use a 15 Watt soldering iron.
Rog
  #49
Old 08-08-2009, 07:58 AM
Brown Falcon
hey guys.
Mitch
Yes, get the solder with silver in it from radio shack. Some guys don't even have to add solder because there's enough left over from the old resistor. I had to add a little to mine though.
Just don't get too big of a size.
  #50
Old 08-08-2009, 12:28 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
Quik question:
I have 2 IDM's one is 100V and one is 120V If I do this mod on the 100v it will be 140v(so I understand). If I do it to the 120v IDM will it still be 140v? I have 2 75ohm resistors (Thanks Rodney!).
My hands are dirty and I am ready to do this, I hope to hear from someone soon.
Thanks
Cope
  #51
Old 08-08-2009, 01:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Originally Posted by Copedawg
Quik question:
Thanks
Cope
Yes they will be 140v, but you need different specifications of the resistor, Im going to see if I found that.
  #52
Old 08-08-2009, 01:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
here you are:
IDM-100 uses a 75.0k Ohm (75,000 ohm) 1/2 watt 1% tolerance Metal Film resistor
IDM-110 uses a 75.0k Ohm (75,000) 1/2 watt 1% tolerance Metal Film resistor
IDM-120 uses a 73.2k Ohm (73,200) 1/2 watt 1% tolerance Metal Film resistor
  #53
Old 08-08-2009, 02:26 PM
kawa's Avatar
kawa
kawa is offline
Does anyone have the digikey part numbers for those resistors? Trying to find them on the digikey web site is a nightmare at best.
Rog
  #54
Old 08-08-2009, 02:45 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
OK I am using the 100V IDM. This one is different! It says it is made in Brazil on the data plate. The guts are all diskombabulated compared to the pics in page 1. I did find the 6042 do-hickey s I supose I will pull it and try the other resistor. There is hardley any room at all!
Anyone wanna add anything?
  #55
Old 08-08-2009, 03:05 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
I think I am done. Can I check it by just pluggging it in and bolting to the side? Maybe leaving the back off....temperaroliy?
  #56
Old 08-08-2009, 03:19 PM
kawa's Avatar
kawa
kawa is offline
YEP! Ya sure can!
Rog
  #57
Old 08-08-2009, 03:55 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
OK I DID IT!!! It started so I am going to ASSuME I did it correctly. I am going to glue it back together. Thanks fellas!
  #58
Old 08-08-2009, 06:00 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
Alrighty, All done! It is a little more "snappier". I spose it is a prelude to other mods ie; injectors, tunes etc. Not bad, I am happy. Thanks for everyones help.
  #59
Old 08-08-2009, 09:04 PM
Brown Falcon
It does give you a little bit of a better feel... Glad it worked out good for you!
  #60
Old 08-09-2009, 10:13 AM
Talyn's Avatar
Talyn
Talyn is offline
I don't have much experience with silver solder, but it is more expensive.
http://en.wikipedia.org/wiki/Solder
Silver is also an excellent conductor. so it makes for good properties. It's bonding strength might not be that of 60/40 Lead/Tin, which is what I generally use.
Remember, the worse thing you can do when soldering is use TOOO much solder.
it should not be bubbled over the component. Just enough to attach it firmly, should create a...
I'll make some pictures. Stay tuned.
Quick Reply: IDM 100 mod w/ pics
