1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
turn signal flasher location
Old 04-19-2009, 12:11 PM
Jason6969's Avatar
Jason6969
Jason6969 is offline
Where is the turn signal flasher located on 2000 F350 diesel looked everywhere and in the manual thanks
Old 04-19-2009, 12:59 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
mnpowerstroke99duty is offline
Why are looking for it? Are the turn signals flashing rapidly,if so check the bulbs?If one burns out the flasher will flash rapidly.If it doesn't flash at all it could be a fuse burned out.I don't think there is a flasher like older vehicles had.I think its intergrated with a few other things but I not 100% sure.
Old 04-19-2009, 02:21 PM
Jason6969's Avatar
Jason6969
mainly just wondering out of curiosity
Old 04-19-2009, 02:45 PM
JockD's Avatar
JockD
JockD is offline
With the engine off, key on, wait for the warning chimes to stop, then select turn signal one direction. Listen for the relay clicking and follow the noise. It should be behind the instrument panel to the right of the steering column somewhere.
Old 04-19-2009, 05:54 PM
john_from_ict's Avatar
john_from_ict
john_from_ict is offline
I removed my radio and felt around to the left of the radio opening and located the flasher by feel while the turn signal was working. IIRC there was a black cover over the top of it as well.
Old 11-07-2009, 10:52 AM
Jack 1999's Avatar
Jack 1999
Jack 1999 is offline
remove panel covering fuse box, next remove the screw holding the heater duct work extension, with the duct work removed you can reach the flasher box cover by reaching up under the dash, remove cover from the box, then remove the flasher, the heavy duty replacement flasher is "taller" and the cover will not fit over it, reverse to close
Old 02-05-2012, 11:10 AM
LWW's Avatar
LWW
LWW is offline
I just changed mine out and documented with pics:
https://www.ford-trucks.com/forums/8...l#post11387637
Old 02-15-2022, 01:24 AM
Vince2021's Avatar
Vince2021
Vince2021 is offline
It is located behind the radio
Old 02-15-2022, 10:19 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Yeah, that was solved a decade ago...
Old 09-14-2022, 02:12 PM
D. Ontaiyabbi's Avatar
D. Ontaiyabbi
D. Ontaiyabbi is offline
4wd Low
Blinkers
2004 f350 6.8
Drove into town went to use the blinkers and there was no response. My hazards work, everything works. But no response from my turn signals, no sound or lights. Just dead.
went to look at the relay and there was only a black one, blue one was non existent. But there's nothing rattling around the truck so I don't know what's going on.
Old 09-14-2022, 03:00 PM
projectSHO89
Check fuse F27 under the dash first.
To find the flasher relay, turn on the hazards and follow the clicking. Same flasher relay runs both turn and hazard signals. Should be somewhere back there behind the radio somewhere. It was moved slightly starting with the 02 model year.
FordTruckChuck
1997 - 2003 F150
08-10-2014 10:06 PM
onriver365
01-06-2013 08:49 PM
yellowboy
2004 - 2008 F150
10-28-2011 06:26 PM
ford1967
01-16-2004 12:46 PM
ford1967
11-03-2003 04:54 PM
Quick Reply: turn signal flasher location
