Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-19-2009, 01:11 PM
Jason6969 Jason6969 is offline
Jason6969 is starting off with a positive reputation.
turn signal flasher location
Where is the turn signal flasher located on 2000 F350 diesel looked everywhere and in the manual thanks
  #2 (permalink)
Old 04-19-2009, 01:59 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty mnpowerstroke99duty is offline
mnpowerstroke99duty is starting off with a positive reputation.
Why are looking for it? Are the turn signals flashing rapidly,if so check the bulbs?If one burns out the flasher will flash rapidly.If it doesn't flash at all it could be a fuse burned out.I don't think there is a flasher like older vehicles had.I think its intergrated with a few other things but I not 100% sure.
__________________
'99.5 F-250 Super Duty,Ext cab,short box,7.3L diesel,Automatic,Detroit locker in rear axle,2 1/2" Tuff Country leveling kit,Rancho RS9000X adjustable shocks,Rancho steering stabilizer,Hypertech power programmer III,Banks trans command,6 disc cd changer,Hunter brush guard,7 1/2' fisher snow plow
  #3 (permalink)
Old 04-19-2009, 03:21 PM
mainly just wondering out of curiosity
  #4 (permalink)
Old 04-19-2009, 03:45 PM
JockD's Avatar
JockD JockD is offline
JockD is gaining momentum as a positive member of FTE.
With the engine off, key on, wait for the warning chimes to stop, then select turn signal one direction. Listen for the relay clicking and follow the noise. It should be behind the instrument panel to the right of the steering column somewhere.
__________________
Jock - 2001 F250 Reg. cab 4X4, 7.3L with CCK, auto, 270,000 mi.
  #5 (permalink)
Old 04-19-2009, 06:54 PM
john_from_ict's Avatar
john_from_ict john_from_ict is offline
john_from_ict is starting off with a positive reputation.
I removed my radio and felt around to the left of the radio opening and located the flasher by feel while the turn signal was working. IIRC there was a black cover over the top of it as well.
  #6 (permalink)
Old 11-07-2009, 11:52 AM
Jack 1999 Jack 1999 is offline
Jack 1999 is starting off with a positive reputation.
remove panel covering fuse box, next remove the screw holding the heater duct work extension, with the duct work removed you can reach the flasher box cover by reaching up under the dash, remove cover from the box, then remove the flasher, the heavy duty replacement flasher is "taller" and the cover will not fit over it, reverse to close
Tags
04 , 1999 , 2002 , 2004 , 250 , duty , f150 , f350 , flasher , ford , location , photo , signal , super , turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
