Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-18-2009, 09:09 PM
svt2205 svt2205 is offline
svt2205 is starting off with a positive reputation.
3 Broken & Still In The Heads
Well today I decided to take the plunge and change my plugs. I soaked over night and still broke 3 plugs. Two of the three broke with the porcelin and the center electrode still in place. The remaining the porcelin broke but the electrode came out with the plug.
The sounds these things make while attempting to get them out will disturb you or at least they did me. One observation I will make, is the 3 the broke were the only one's I decided to turn out a little and then turn back in. I'm thinking I should have just kept going and not turned back in.
Ah, I don't frigin know. What I do know is I'm not sure how the heck to get these dam things out. I have given up for today and left these three soaking in Kroil.
What the heck can I do, other then use my AAA and have it towed to my local dealership. Is it possible to use some thing like a long handled awl and break away the porcelin without causing the plug tips to end up in the cylinder?
I'm hoping someone has a great suggestion so I can get these dam things out.
(I posted this over on F150online, I'm looking for all the help I can get)
__________________
07 F150 Lariat Supercab, 6.5' 4x4, 5.4, 3.73LS, 7.5' Fisher SD Plow
  #2 (permalink)
Old 04-18-2009, 09:49 PM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 is starting off with a positive reputation.
there is a tool you can buy that is made to remove the broken pieces. I can't remember the name though, hopefully someone else will chime in.
  #3 (permalink)
Old 04-18-2009, 09:59 PM
firstonraceday's Avatar
firstonraceday firstonraceday is offline
firstonraceday is gaining momentum as a positive member of FTE.
The Lisle #65600 is the removal tool.
__________________
Jason
2005 F-150 XLT SuperCrew, 5.4 w/Auto, 3.55LS
1993 F-150 300 I-6 w/5-Speed (Traded for the above 8/6/2005)
1977 F-250 351M w/T-18 (Rebuilt at 315,000 Miles)
2008 Escape Limited w/3.0L V-6 (Wife's)
  #4 (permalink)
Old 04-19-2009, 03:44 AM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
PM Sent
sorry, but we can't link you to other sites. But what I sent you is a pretty nifty DIY way to remove them.
btw, Matco and Snap-On both make a tool for the removal as well.
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..F'ing quick
Currently deployed. See y'all on the flip-side.
  #5 (permalink)
Old 04-19-2009, 08:40 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
The Lisle tool works the best. If the electrode is broken flush the tool will work on it as well. If it is protruding above the porcelain you should be able to work it out or break it off flush with needle-nosed visegrips. Good luck.
  #6 (permalink)
Old 04-19-2009, 08:57 AM
bomber468 bomber468 is offline
bomber468 is starting off with a positive reputation.
When I was going to change the plugs I called Ford to see how much the special tools was and if I remember correctly it was about $200. It takes a few days to get too.
  #7 (permalink)
Old 04-19-2009, 09:30 AM
pkvir's Avatar
pkvir pkvir is offline
pkvir is starting off with a positive reputation.
I was under the impression that Ford put different heads (or something) on the 07-08 to keep this from happining. Did I make this up?
Am I going to have this problem with my 09?
__________________
2009 Lariat 4X2 Screw 5.5 bed (Sold)
2010 Fusion Sport FWD
Sport Blue, Black Interior
Moon and Tune, RSS
  #8 (permalink)
Old 04-19-2009, 12:09 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is online now
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
Ford changed the heads in late 07...so no..your 09 is not affected...
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #9 (permalink)
Old 04-19-2009, 12:17 PM
jsoko's Avatar
jsoko jsoko is offline
jsoko is starting off with a positive reputation.
Quote:
Originally Posted by tylus View Post
PM Sent
tylus; can you show the "nifty DIY tool"
and any info on the "special socket" I hear about
thanks
__________________
"For those who have fought for it, Freedom has a taste the protected will never know"
'06 F150 4x4 5.4 XLT SB EXT CAB BLACK
'77 F100 RANGER XLT 392 STROKER CHEVY & HEMI SMOKER
  #10 (permalink)
Old 04-19-2009, 03:56 PM
tylus's Avatar
check your Private Messages
1 link is about that
the other link, go down to post 10
sorry I can't be of more help. It's not encouraged to link to other forums
__________________
  #11 (permalink)
Old 04-19-2009, 06:00 PM
Success!!!!!
Thankfully this BS is OVER.... I was able to track down a pair of super long reach pliers that allowed me to pull out the center electrodes. I tried to pull them using the threaded rod loctited (648) and cured for almost 2 hours. Dam threaded rod pulled right out of the porcelin. So, out came a sharp pointed drift and a hammer. A couple hours later the remains of my 3 broken plugs were OUT!!!!
I was thrilled as I was putting my new plugs, Motorcrafts by the way, in. My truck now idles like new.
Thanks one and all for your help and all.
FYI, my truck is an 07 with 64K on the clock. I've not measured the gaps on the plugs that came out but they were huge, probably twice the new plugs. (come to think of it, I didn't check the new ones, ah hell, guess what ever Motorcraft set them at will be just fine.)
__________________
  #12 (permalink)
Old 04-19-2009, 06:51 PM
Matt983's Avatar
Matt983 Matt983 is offline
Matt983 is starting off with a positive reputation.
Glad to hear you got them all out and your truck was only down a day! cool stuff!
__________________
~ '04 FX4 SCrew: S&B CAI, diablo sport tuner, Borla Catback, 17" moto metal wheels with interco trxus 35" tires
  #13 (permalink)
Old 04-19-2009, 08:19 PM
tylus's Avatar
07 with 64,000 miles?
wow you drive alot. glad to hear they all came out okay
__________________
  #14 (permalink)
Old 04-20-2009, 05:09 AM
Yup, I do.
Me too.
__________________
  #15 (permalink)
Old 04-21-2009, 11:44 AM
Oldguy4 Oldguy4 is offline
Oldguy4 is starting off with a positive reputation.
Quote:
I was browsing my owners manual this morning and came across a little note that said, spark plug gap is not adjustable on, I think it said, the 5.4 engine.
__________________
2007 F150 XLT SCREW 4 X 4, 5.4, 3.73 LIMITED SLIP, TOW PACKAGE. CHROME DOOR HANDLES TRUXEDO TONNEAU COVER, TTT TOW MIRRORS.
"I would rather push a Ford than drive anything made by GM."
Tags
65600 , bpr65 , broken , extractor , f150 , ford , kit , lis , lisle , matco , plug , porcelain , pusher , spark , stuck , tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
