thank you
the champion will not last as long as MotorCraft
PS: the Champoin is not one peice it is also crimped/pressed below the hex
Double PS: RESEARCH/SEARCH
let me know what you find out
__________________
"For those who have fought for it, Freedom has a taste the protected will never know"
thank you
Champion One piece plug. Just put them in and they run better then the motorcrap plug. I think you would be crazy to keep any plug for 100,000 miles. Pull them at 50,000 intervals.
Boy, that sure looks like a one-piece standard plug unlike what some other smart-a$$ know-it alls on this site would have you believe. Thanks for the info and the pic. I appreciate it.
So Flash, you are certain the Champion plugs are a one peice design?
Why don't you look carefully at this photo. In this you will notice a groove to the right of the threads. In this groove, you will also notice a bit of blue color. This Flash, is where Champion laser welded the 2 peices together. It appears to be a better design then that of Ford's plug, but it is in no way one peice.
wow what do you know about that
some people are like cattle, they need proding
others wont do research; and depend on others for info and still get it wrong
champions can also seperate
better off installing MotorCraft following the TSB
__________________
Unless you are running performance parts, just stick with OEM plugs. By performance parts...I mean a Blower or extensive internal motor mods.
Motorcraft stuff is very high quality that works. Champion seems to be hit or miss. Some like Ryan never have an issue. But I know others on other sites who have nothing but problems.
All I can say is I bought the Champions yesterday and they look and feel just like any other long shank spark plug Ive ever seen. I didnt see any crimps, or otherwise. Just a plain ol' spark plug. Perhaps they changed the design. It also looked like is was quality-made.
Guys....respect each other...i don't care if you disagree...but don't be jerks...
And....the champion plugs ARE one piece....welded is one piece....try and take a welded plug apart....its not comin apart...
I don't know if champion has changed the plug from its initial design cause its been a long time since i've seen anyone thats had a problem with them, AND...they are double platinum plugs that champion says are good for 100K miles...
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
