Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 06-20-2009, 01:53 PM
Muddedprairie's Avatar
Muddedprairie Muddedprairie is offline
Muddedprairie is starting off with a positive reputation.
Yea this scares me have to death as well. But it is something that i have to do... What plugs are you guys using?
Mark
__________________
06-FX4 3-inch lift 35-nitto mud grapplers 2.5 inch leaveling kit, K&N air filter and intake,Throttle body spacer,flow master 3' exhaust,Edge performance box, tinted windows...
  #32 (permalink)
Old 06-20-2009, 08:42 PM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
I replaced mine with #7989 Champion and have had no problem in 8000 miles. Just my personal preference. They are a one piece plug.
  #33 (permalink)
Old 06-20-2009, 11:30 PM
60fordman1971 60fordman1971 is offline
60fordman1971 is starting off with a positive reputation.
When you start- make sure you have lots of time. Time is your friend while taking on this task.
Remove the coil packs and fill the spark plug hole with 1/2" of penetrating fluid and let it sit for at least 15 - 20 mins. You will need the special 9/16" socket designed for these plugs (I recommend also purchasing locking extensions). Take your time when removing the plug by turning an 1/8 of a turn forward and then back. Repeat until the plug is free. The ones that I broke didn't give me any warning, they just broke. From what I can tell, the section of plug after the threads siezes in the head. While removing them, the crud wedges it tighter and creates all sorts of issues. So like I said earlier, take your time.
Also, the TSB recomends to add a thin coat of anti-sieze to the smooth portion at the end of the plug.
Goo Luck!!
  #34 (permalink)
Old 06-21-2009, 12:13 AM
nlfireblade's Avatar
nlfireblade nlfireblade is offline
nlfireblade is starting off with a positive reputation.
Dunno if this has been discussed but is there a product that can be added to the fuel to soften the build up on the area of the plug in the combustion chamber before removing them? Seems like a million types of 'cleaners' out there for carbon, etc. Would running a couple tanks with some such product added prior to changing plugs help
  #35 (permalink)
Old 06-21-2009, 11:23 PM
When I changed mine at 70K I let them soak for 3-4 Hours and I broke 7. I would recommend using the recommended Motorcraft carb. cleaner to soak the plugs. I used DeepCreep and it did not work. The only plug that came out I left it until the next day. It was hard all the way out. Get the lisle tool to have it on hand.
  #36 (permalink)
Old 06-22-2009, 01:32 PM
edouble33 edouble33 is offline
edouble33 is starting off with a positive reputation.
Someone should know. Why does not ford have a recall or special policy on this repair. I work at a local body shop who does a lot of business with the ford dealership right up the road, maybe i should call the service manager, that i kind of know and ask him for a policy adjustment on the plugs.
  #37 (permalink)
Old 06-22-2009, 02:20 PM
jsoko's Avatar
jsoko jsoko is offline
jsoko is starting off with a positive reputation.
Goo Luck!!
what? special 9/16" socket are you talking about
__________________
"For those who have fought for it, Freedom has a taste the protected will never know"
'06 F150 4x4 5.4 XLT SB EXT CAB BLACK
'77 F100 RANGER XLT 392 STROKER CHEVY & HEMI SMOKER
  #38 (permalink)
Old 06-22-2009, 06:02 PM
pb34's Avatar
pb34 pb34 is offline
2006 Ford F-150
pb34 is starting off with a positive reputation.
Quote:
It's not necessarily a special socket. It is just a 9/16" spark plug socket and they aren't all that common.
__________________
2006 F150 Screw XLT 5.4 4x4
Volant CAI w/ Powercore
Hella Optilux Fog Lamps
Extang Tonneau Cover
Magnaflow SIDO 16614
Edge Evolution
  #39 (permalink)
Old 06-22-2009, 06:33 PM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
Quote:
that seems to be the best bet
crack the plugs a tiny bit loose, then flood the cavity with penetrant like the Carb Cleaner, or whatever else the TSB says
refill periodically as it evaporates or wicks down
I personally would let it sit for 24 hours with the stuff doing it's magic...getting impatient seems to be a common factor with breakage
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..F'ing quick
Currently deployed. See y'all on the flip-side.
  #40 (permalink)
Old 06-24-2009, 02:41 PM
Fishin76 Fishin76 is offline
Fishin76 is starting off with a positive reputation.
ok, let me think and do some math, if it takes 1/2hr per broken plug to remove them with the lisle tool, then 4 hours + time to create access for passenger rear plugs and remove c.o.p.s. so your looking at 6-8 hours if your handy. if you follow the TSB, soak each plug for 15 to 20 minutes, you add 20 minutes if you do them all at the same time. Probably take 15 to 20 minutes a plug to work them out, if your lucky and don't break any. So, if you follow the TSB ( and I'm not saying not to!) your looking at 2 hr and 40 minutes to remove the plugs, 20 minutes to soak all the plugs, and 2-4hrs to create access to pass. side plugs, and remove c.o.p.s. (includes re-installation time).
2:40 + :20 plus 2 to 4 = 5 to 7 if you don't break any. if you break any, then add 30 minutes for every broken plug.
Ford dealers use the rotunda tool to fix this, which is not as fool-proof as the lisle tool seems to be. So if the ford dealer does this job, and screws it up with the rotunda tool, they will have to take the head(s) off. BIG $$$$$ if not under warranty.
So does it pay to be careful or patient with removing the plugs. Maybe not.
Zip them out, break them off, use the tool, and be done in 6-8 hours = $80 bucks for lisle tool (have seen them for $75 plus ship). + $100 for plugs ( have seen new one pc'ers for $11 plus tax.) and a bottle Kroil or PB blaster or your favorite penatrant. $8 bucks. (or less). = ~$200 bucks
Dealership service. Per hour + parts. 5-7 hours. Since they are 'professionals' lets say 6 hours of them following the TSB in the shop. last time I looked, the motorcraft two pc'ers were $18 a piece ($144) , My ford dealer has a big sign that says 65 per hour labor, so I'll use that. 6 x 65 = $390 labor. SO, $144 + $390 = $534 plus tax. Don't forget to add $65 for each 2 plugs that break while the tech is working on it. If they REALLY screw up, its likely be over a grand (total with plugs) to pop the heads. and more part costs too.
Yes, some dealers will feel bad for you and cut you a break on some of it. But don't count on it.
Just my perspective on this topic and humble opinion.
thanks for reading.
Now, If you would normally value your time as the labor higher than $65 an hour, then this argument does not work, but my time is not worth that much. So don't preach to me that you make more than 130K a year, and is not worth your time. ($65/hr x 2000hr a year).
__________________
These are not the Droids you are looking for.....
Current vehicles:
98 Contour 2.0L auto, my new DD 49K 30mpg
2009 Dodge Grand Caravan SXT 3.8L 6sp auto
1986 F250XL Diesel RC LB 4x4 T19 4spd 4.10's?
  #41 (permalink)
Old 06-24-2009, 08:40 PM
Fishin76, Plan on it being a weekend project and have the Lisle tool kit on hand. Use the Motorcraft Carb. cleaner on hand, let the engine cool off. Disconnect the battery. Loosen the plugs 1/8 turn and put the carb cleaner as per TSB. Let them soak overnight. I learned the hard way. Patience!!!! The next morning they will be easier to remove. To get access to the #4 plug you can unbolt and lay the PCM out of the way. If any do break off hope they are the front ones. Good luck.
  #42 (permalink)
Old 06-25-2009, 08:42 AM
rkedz rkedz is offline
rkedz is starting off with a positive reputation.
Vacuum caps for broken plugs
Would anybody know what size vacuum cap to use if porcelin comes out? I have everything except them. Fords vacuum cap is 382444-s can't seem to be found. I know that I will use some grease but would like that extra protection. Any help on plug size would be great. Preparing for the worst.
Thx
  #43 (permalink)
Old 06-26-2009, 11:18 PM
HYPO HYPO is offline
HYPO is starting off with a positive reputation.
Quote:
Thx
Two possible suggestions:
1) Use a small wad of chewing gum
2) Cut a small wad of that gray/ black packing foam, it's compressable
HYPO
  #44 (permalink)
Old 07-03-2009, 11:30 PM
motown's Avatar
motown motown is offline
motown is starting off with a positive reputation.
Quote:
I ran marvel Mystry Oil in every tank I used a month prior to changing my plugs. Every one came out like butter and I had 44,000miles on my truck prior to changing them. The Marvel Mystry Oil, has mint oil which disolves carbon. My plugs where pretty clean of carbon when I removed them. A couple of other members have tried my method and have had the same results.
  #45 (permalink)
Old 07-03-2009, 11:46 PM
pb34's Avatar
2006 Ford F-150
Quote:
I'm right there with ya! I have always run Marvel Mystery Oil in my vehicles and it really pays off! My plugs came out without any issues.
__________________
Edge Evolution
Tags
65600 , bpr65 , broken , extractor , f150 , ford , kit , lis , lisle , matco , plug , porcelain , pusher , spark , stuck , tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
