Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 04-21-2009, 11:51 AM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith XL1200LTD-Keith is offline
XL1200LTD-Keith is starting off with a positive reputation.
Here are some links to the tools.
Lisle Ford Broken Spark Plug Remover LIS 65600 (Alt 303-1203 303-1398) | Hard to Find Automotive Specialty Tools
Rotunda 303-1203 Broken Separated Spark Plug Removal Tool | Hard to Find Automotive Specialty Tools
  #17 (permalink)
Old 04-21-2009, 02:38 PM
RISUPERCREWMAN RISUPERCREWMAN is offline
2007 Ford F-150
RISUPERCREWMAN is starting off with a positive reputation.
Glad to hear about your success!..Way to go!
  #18 (permalink)
Old 04-21-2009, 03:08 PM
tomclem tomclem is offline
tomclem is starting off with a positive reputation.
I'm curious now. Ok, you got the porcelain out but how did you get the electrode sleeve out?
  #19 (permalink)
Old 04-21-2009, 08:03 PM
svt2205 svt2205 is offline
svt2205 is starting off with a positive reputation.
I never realized that I didn't post that I have the Matco Extraction tool. I was so stressed during this process that it doesn't suprise me I didn't mention that.
If I hard to do this again, I think I would buy this matco tool vs the one I bought.
FORD BROKEN PLUG REMOVER
Removes broken spark plugs from 2004 and newer Ford Triton 3 valve per cylinder engines.
Unique porcelain pusher is used to press the porcelain piece, without breaking the porcelain, farther into the plug tip.
Pushing the porcelain provides space for the left hand threaded remover to bite into the plug tip that is stuck in the head, so it can be puller.
Blow-molded storage case included.
Part#: BPR65 Price: $109.95
This is the one I used.
FORD SPARK PLUG EXTRACTOR
Specially designed guide works in conjunction with a 9" Tap and Extractor Screw to make sure the spark plug sleeve is tapped straight making it easier to extract
Pulls brokes spark plug sleeves out of 2004 to present Ford triton Engines
Part#: FSP100 Price: $81.95
The hardest part to this whole process is getting up the nerve to hammer away at the procelin. I had no idea that the metal tube that breaks off actually as a larger diameter at the plug body. I was afraid hammering it would cause it to drop down into the cylinder. But that's not the case.
I'm glad this is all behind me.
Who's next?
__________________
07 F150 Lariat Supercab, 6.5' 4x4, 5.4, 3.73LS, 7.5' Fisher SD Plow
  #20 (permalink)
Old 04-21-2009, 08:19 PM
4DTech's Avatar
4DTech 4DTech is offline
4DTech is starting off with a positive reputation.
Just for your info I didn't see it in here any where but on the new plugs put anti sieze on the electrode metal tip, not the threads or the very tip of the electrode. Part of the TSB. Helps cut down carbon build up on the tip. On my 05' F-150 I changed the plugs @ 40,000 miles and plan to do it again @ 80K. I have a socket that I use that is designed not to shift or angle when removing to prevent poss. breaking. I've done many plugs at the shop with no broken ones. Long method to type out my own concauction and chemical mixture. But it works the key is if they make noise coming out there ok. Well Congrats and good luck in the future.... Oh and by the way if anyone doesn't know DO NOT use autolite plugs in the 3V engine I've pulled out plugs that the electrode has melted at the tip.. Word to the wise.
  #21 (permalink)
Old 04-23-2009, 12:45 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
I bought the Lisle tool and a Snapon tool, also. The Snapon toollooks identicle to the Rotunda tool in the picture but has a guided tap tool with the kit.
  #22 (permalink)
Old 04-23-2009, 09:49 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
the Lisle tool really looks to be a much better tool than the rotunda tool to me....anyone thats used both have an opinion?
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #23 (permalink)
Old 04-23-2009, 10:36 PM
Ted928 Ted928 is offline
Ted928 is starting off with a positive reputation.
Glad you got them out. Please explain what you did during your attempt to remove. Did you follow the tSB? Did you crack them 1/16 of a turn and presoak with kroil????
__________________
2005 SCREW 5.4L
  #24 (permalink)
Old 04-24-2009, 05:45 AM
Yup, followed the TSB, soaked in kroil and removed things like the PCM to gain access to the passenger side rear plugs. Then using a drift, ground to a sharp point. I hammered the remains of the porcelin until I could get the tap in a few threads. Then I just used the Matco tool to get the remains out.
Basically, if you follow the TSB and what many folks here and other sites list for methods, you'll be fine.
That said, I now have a the smell of raw fuel when I start my truck and as the days have gone on, it's getting stronger. Last night I replaced fuel injector orings, as I pulled one fuel rail to give me a little more access when breaking up the porcelin. I've looked all over the engine, and below. There's no sign of fuel. Now I'm thinking it could be associated with the EVAP purge valve, as I did remove one line (couldn't get the other off) and unbolted it from the firewall. Maybe I messed it up.
Never fails, fix one thing and something else happens.
__________________
  #25 (permalink)
Old 04-24-2009, 06:59 AM
When I used the Lisle tool I did not have to chip out any porcelain. I ran the pusher tool down once then removed and blew out chips and repeated the procedure. Then I installed the puller and removed the heatshields. The pusher tool pushes the porcelain down to the ground electode which makes enough room for the puller. I had to use the Snapon tool kit because I tightened the Lisle puller to tight and stripped out the top portion of the heatshield. Obviously operator malfuntion.
  #26 (permalink)
Old 04-25-2009, 08:54 PM
Sounds like that's a much better tool then what I used. But at this point, it's now just a paper weight, unless someone I know is going to attempt this job.
So, who's trying this fun job next?
__________________
  #27 (permalink)
Old 04-25-2009, 09:09 PM
Quote:
Originally Posted by svt2205 View Post
Yup, followed the TSB, soaked in kroil and removed things like the PCM to gain access to the passenger side rear plugs. ....
But you did follow the TSB and they still failed???
__________________
2005 SCREW 5.4L
  #28 (permalink)
Old 04-26-2009, 06:55 AM
Yes, following the TSB reduces your chances for breaking plugs. It doesn't mean you absolutely wont break any. There's a thread here some place that has tons of posts with people who had sucess and others, like me, who had issues.
And unless you're using the specific chemicals as stated in the TSB anyone of us who used Kroil or other solvents, did not follow the TSB. Is that a factor, who knows.
If you choose to change them yourself, be prepared and understand the challenges associated with a simple plug change.
Good luck
__________________
  #29 (permalink)
Old 06-20-2009, 12:37 AM
60fordman1971 60fordman1971 is offline
60fordman1971 is starting off with a positive reputation.
Plugs
Just changed my plugs in my 06 with 116000 miles and I also broke two plugs. The tool is down to $100 and is well worth it!
  #30 (permalink)
Old 06-20-2009, 01:13 AM
john04 john04 is offline
john04 is starting off with a positive reputation.
hey how you all doing today? i just bought a 2004 ford f150 with the 5.4 in it good running truck i really like it. its got 85,000 miles on it onlything i dont like is the spark plug problem i have not yet tryed gonna wait a little longer since they are 100,000 mile plugs but anyone have any ideas i can write down on a peice of paper or ideas so when its time to do the job i have a good idea what to do thank you all on hear
Tags
65600 , bpr65 , broken , extractor , f150 , ford , kit , lis , lisle , matco , plug , porcelain , pusher , spark , stuck , tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
