Holley 1850 - mechanical secondaries - Ford Truck Enthusiasts Forums
Old 04-18-2009, 04:22 PM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
I've just picked up an almost brand new Holley 600 carb that I will use to replace my 2150 feedback with, on a basically stock 351W in an 83 F250, for $100NZ (about $56US)
It was on a 327 Chev for 3 months before the engine died.
It has mechanical secondaries - are there any disadvantages with these over vacuum?
Thanks
Old 04-19-2009, 02:20 AM
With some googling, I suspect it may not be an 1850, but a 600cfm 4150 double pumper. If so, is this going to be a hungry headache in a basic work-truck?
Old 04-19-2009, 03:31 AM
wdfp wdfp is offline
wdfp is starting off with a positive reputation.
A double pumper will usually burn more fuel than a vacuum secondary which they are designed to do actually, more performance minded than economy. But most economy is in your right foot anyway. If you stand on it with lower rpm's it might bog when the secondaries open too early but if you drive sensible it should work almost as well as a vac carb would.
Old 04-19-2009, 07:27 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
What is the LIST# on the right front of the choke horn in the front?
Old 04-20-2009, 02:08 AM
6R 5534 B
All 4 barrels equal dia. - 42mm at a quick measure
Old 04-20-2009, 04:06 PM
LxMan1's Avatar
Can you post a picture of it?
Old 04-21-2009, 03:12 PM
Yes, can do so - it might be a day or so
Old 04-22-2009, 05:16 PM
LxMan1's Avatar
Sounds good.
Old 04-24-2009, 03:01 PM
79f2506.6L 79f2506.6L is offline
79f2506.6L is starting off with a positive reputation.
6r 5534 b is a 650 cfm double pump carb
Old 04-25-2009, 10:25 PM
LxMan1's Avatar
It doesn't list that number on Holley's site.
Old 04-26-2009, 05:04 AM
I couldn't find it either, but it's the correct number.
I'll get the photos & post them tomorrow
Old 04-30-2009, 07:32 AM
Finally got them
Old 05-06-2009, 04:20 AM
Nailed it down - it is a 650 d/pumper, list is 4777-3. I didn't see that at first.
It would be a good carb for someone - but I'm not so sure about using it on a low rpm - high torque, reasonably heavy, work truck.
Old 05-06-2009, 04:01 PM
LxMan1's Avatar
It is a good carb. An 0-1850 would be a better choice it sounds like though.
Old 05-06-2009, 05:07 PM
Beechkid Beechkid is online now
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
making sum assumptions, i calc'd out the cfm for the 351...
My assumptions were:
max RPM is 5500
volumetric efficiancy is 85%
With that given, it calc'd out to 475 cfm. The 650 is a little big but it is a good carb. i would try it, if it bogs a tad then try jetting (fuel) it down by 12% and that should put you right in the ballpark of where you need. (if the jet size is 72, multiply 72 times .12+ 8.6 or jet #64)
460 w/ Holley 4180 4V - Secondaries not Opening quakerj Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 12-05-2014 11:37 AM
Holley 4180C - Vaccum Secondaries quakerj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 11-17-2013 12:02 PM
issues running double pumper? 68cabby Ford Inline Six, 200, 250, 4.9L / 300 22 03-29-2013 12:16 PM
Chokeless Carb 68Ford4Life 1967 - 1972 F-100 & Larger F-Series Trucks 20 01-18-2012 05:26 PM
Secondaries Won't Open on Holley Boss50 Fuel Injection, Carburetion & Fuel System 6 08-15-2007 03:45 AM
Tags
01850, 1850, 351w, 5534, 5534b, 600, 64, 6r, carb, cfm, double, holley, mechanical, pumper, secondaries, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
