Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-18-2009, 01:41 PM
pjnadon's Avatar
pjnadon pjnadon is offline
2002 Ford F-350
My Garage
pjnadon is starting off with a positive reputation.
Disable Door Chimes
I am wondering if i can disable the keys in the ignition door chime without screwing any thing else up. It gets real anoying when you want to listen to the radio with the door open.
  #2 (permalink)
Old 04-18-2009, 02:57 PM
boone1965 boone1965 is offline
Garage is empty, add now
boone1965 is starting off with a positive reputation.
Take the steering column cover apart, remove 4 screws from underside so bottom of cover puuls apart. You will notice a small hole on teh underside of the ignition key cylinder. With you key in and a small drift punch in teh hole, push up on the punch as you turm the cylider slowly while pulling out on teh cylinder. The cylinder will come out with th ekey in it. Find a small black wire and disconnect it and cap it off. It sends a signal when grounded so make sure to insulate it good. Tuck it under teh column and reinstall in reverse order. The key will chime when first inserted and then stop. Open your doors and listen away. There is an actual posting on this forum and that is how I disconnected mine.
__________________
Daniel
99.5 F250 4x4 Extcab, 6spd,4" exhst, Cold Air intake,CCV, WW,203therm,SShpx,Regulated FPR, Boost annialator, zoo-dad, AIH Delete, Harpoon and Hutch Mods. 3.0 lift with 305's DP Tuner F6.
  #3 (permalink)
Old 04-18-2009, 03:46 PM
7.3 Rocket's Avatar
7.3 Rocket 7.3 Rocket is offline
Non-smoker
7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future7.3 Rocket has a brilliant future
A simpler way to do it is pull a fuse. I believe it is #14.
It controls the chime and dome light. Just pull that fuse out and presto. No more chime.
__________________
-Pete, PAA member #84
  #4 (permalink)
Old 04-18-2009, 06:17 PM
surveyguy surveyguy is offline
surveyguy is starting off with a positive reputation.
depending on the choice you made, you may also want to unplug the seatbelt ding too, under the seat.
__________________
'03 7.3L CC SD PS, ccv mod, "Ding" del, 4" exhust, 6637, EPBV del, foil del, 17"rims, timbrens (guages soon, thanks Robin!) 1 1/4" rear anti-sway bar, airbags, muffler del.
94 F150 300-I6 SB 4X2 5-spd 170k 1 owner, no prob's, 4way airbags, 3.05 rear, haul 2000#
96 Lance squire lite, 82 CE vette (I know)
94 kawi vulcan 750, VW, mopar, jet ski's, (no wife)...
Tags
2003, 2006, 2007, car, chime, chimes, disable, door, escape, f150, f250, ford, powerstroke, ranger, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
