Low Fuel Warning light. How many gallons left - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 04-18-2009, 12:50 PM
soutthpaw's Avatar
soutthpaw soutthpaw is offline
soutthpaw has a good reputation on FTE.soutthpaw has a good reputation on FTE.
The owners manual does not give a specific, so I am wondering if anyone knows how much fuel is left when the Low Fuel Warning light comes on for the 7.3L diesel.. did not find the answer in a search ... I tried
Old 04-18-2009, 01:42 PM
4X4X4RV's Avatar
4X4X4RV 4X4X4RV is offline
4X4X4RV is starting off with a positive reputation.
As far a I know, the low fuel light is preditive it will come on at a avarage fill up time.
Lets say you always fill up at a 1/4 tank then it will come on at a 1/4 tank were if you always fill when it reaches the red line it will come on there.
I have ran mine way below the red line ( not good ) were it took 26 gallons to fill up ...
Old 04-18-2009, 02:44 PM
gr8scott72 gr8scott72 is offline
gr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant futuregr8scott72 has a brilliant future
Not true. Light comes on the same level everytime regardless of when you fill up.
I do know that on mine, once the overhead says 0 miles to empty I still have about 5 gallons past that. I know this because the last fill-up, I actually pumped 44 gallons.
Old 04-18-2009, 02:55 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Mine comes on with 8 gallons left.
Old 04-18-2009, 04:21 PM
t-rexx's Avatar
t-rexx t-rexx is offline
t-rexx is starting off with a positive reputation.
You must mean 36 gallons?
For mine, once the light comes on, I have approximate 7 gallons left in the tank.
Old 04-18-2009, 08:45 PM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE.1 is gaining momentum as a positive member of FTE.
I have a V10 but I need about 36-38 gallons to fill up after my light comes on. I think when my overhead console went to 0 miles to empty I filled up with around 39 gallons. My fuel pump hates me...
Old 04-18-2009, 08:47 PM
1's Avatar
1 1 is offline
If your below the red and filling up with 26 gallons something is wrong with your gauge or fuel level sending unit in the tank.
Old 04-18-2009, 10:09 PM
4X4X4RV's Avatar
Brain dead Me 46 gallons .......... Then I wonder why I don't post so often LOL
Old 04-18-2009, 10:28 PM
Monsta's Avatar
Posting more makes one less brain dead...oh wait...that's not right...
Old 04-18-2009, 10:35 PM
4X4X4RV's Avatar
Thanks for the support ............
Old 04-18-2009, 11:42 PM
blowhole's Avatar
blowhole blowhole is offline
blowhole is starting off with a positive reputation.
Wait a minute, I thought the Ex only had a 44 gallon fuel tank. How are ya'll's numbers supporting this? Am I wrong with the 44 gallon tank size? I believe I read in the owners manual it was 44 gallons.
Please advise.
Old 04-19-2009, 12:43 AM
afreemanmd afreemanmd is offline
afreemanmd is starting off with a positive reputation.
you're right, its 44 gal.
but maybe if you keep topping off you might get an extra gallon or so maybe?
Old 04-19-2009, 01:46 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
It varies from rig to rig. The float in the tank only provides a general approximation, not a specific amount of fuel left.
Think about it, if the gauge were to show the specific amount, when the tank sloshes to and fro, your indicator would rise and fall with the sloshing.
My Ex is more predictible than my F250. I've had the light come on for my F250 while tooling down the freeway, then 10 minutes later, go off. I've also had it come on while driving home, then the next day it's off, and it stayed off for two more days!
Stewart
Old 04-19-2009, 10:06 AM
soutthpaw's Avatar
A lot of vehicles will give you a specific, My wife's Audi for example is like 2.6 or 3 gallons, its in the owners manual
Old 04-19-2009, 01:38 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
My 2003 Excursion 6.0L diesel (not sure if gas motors are different) holds 44 gallons.
My "warning light" comes on with about 60 - 80 miles to go and I have even ran it down to when the overhead console said I had "zero miles" left!!!
When I pumped diesel into my tank, I could get 41 gallons in... so that meant I had between 2 - 3 gallons left or an additonal 30 miles before I ran bone dry (which you should never do in a diesel)!!!
low fuel light WilliesSD250 6.0L Power Stroke Diesel 9 07-25-2013 10:57 PM
Low Fuel warning relearn????? rdalley 1999 to 2016 Super Duty 18 10-28-2011 11:56 AM
Fuel warning light and reserve fuel capacity perryg114 Excursion - King of SUVs 31 01-03-2011 03:10 PM
Low Fuel Warning SilverE350 1968-2013 Full Size Vans 0 10-21-2010 05:54 PM
Low fuel light desert sled 1999 - 2003 7.3L Power Stroke Diesel 3 11-28-2009 06:34 PM
Tags
2000, 2004, 99, f150, ford, fuel, gallon, gallons, gas, left, light, miles, on, ranger, red, tank, turns, xterra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
