Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 06-24-2009, 02:15 AM
dwg999 dwg999 is offline
dwg999 is starting off with a positive reputation.
I checked the pressures and the following are the results:
@ 1500 rpm
High - 265" - 285"
Sprayed water directly onto the condenser and the pressure dropped rather quickly to 200". This would indicate that I likely need to replace the fan clutch which I will probably do.
@ 1500 rpm
Low - 40" - 45"
After spraying the condenser the pressure dropped to approx. 32".
Are these pressures reasonable?
I also found a label under the hood indicates 2 lbs. 6 oz. (38 oz.s) of r134a which means I am slightly under this quantity considering that I used about 34 oz.s.
  #17 (permalink)
Old 06-24-2009, 08:06 AM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
@ 1500 rpm
High - 265" - 285"
Yep. The fan clutch is toast. Get a Motorcraft fan clutch! Many aftermarket clutches fall short at idle and aren't much better than your weak OEM unit on a converted system. They also don't seem to last very long.
Hose out the radiator and condenser fins with detergent and water while you're in there replacing the clutch.
@ 1500 rpm
Low - 40" - 45"
Yes.Once the condenser was cooled, the pressures fell right in line. Post them again after you replace the clutch. 1500rpm, Max AC, High blower, doors open. Post the ambient temp, too.
You're in the ballpark. Once you replace the fan cluitch, you can measure the temp of the evaporatoir inlet and outlet pipes and tweak the charge if need be. You have to fix the airflow issue first.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #18 (permalink)
Old 06-27-2009, 12:54 PM
Beoweolf Beoweolf is offline
Beoweolf is starting off with a positive reputation.
Is there a work around - instead of replacing the Whole system?
I read your very through and informative post. To be honest, as much as I love my Bronco - its just not possible to come up the money to replace as much as you did. Even though I want to and intend to keep this Beauty on the road for long, long time - I just can't come up with the entry fee right now.
I had looked into purchasing one of those A/C eliminator pulley's for 351 W, which are sold through SVT/FMS. Basically, you remove the A/C compressor - replace it with the pulley an stand; it allows you to keep the serpentine belt routing as factory.
It seems like a good option, until I can build up the war chest. What I don't want to do is go the cheap route, end up contaminating the system or doubling the cost thru false economy.
Symtoms: The compressor started making noises, then eventually stopped turning. At that time, I figured it was only a defective clutch. since than the A/C compressor has frozen ... when I removed the belt, the clutch would not even turn (frozen solid). I'm "guessing" the unit is toast.
What would you suggest (then the obvious - do the repair!) the will allow me to get it back on the road? If you think the bypass pulley idea will work - what would be the best way to minimize additional damage to the rest of the system/hoses/etc. until I can get it disassembled and repaired?
I hate being cheap, but times are tough ... this is the better alternative than giving up my '95 Bronco. I was using my '81, but it was just got totaled this week. Someone Broad-sided it (ran a signal) at 50 mph ~. Broke the front axel, bent the frame, engine moved - I'm pretty sure it saved me from worse personal injury - these are some rugged pieces or rawhide.
  #19 (permalink)
Old 06-27-2009, 06:05 PM
Just grab a compressor from the local Pick and Pull and bolt it in place. That will keep the lines connected so dirt doesn't get in. When the clutch isn't engaged, it's just an idler anyway. My local self service yard gets about $20 for a compressor, much better than 50-75 for the idler kit.
It sounds like your compressor grenaded internally. I'd say you're looking at a compressor, condenser and accumulator at minimum. Post back when you are ready to repair it.
__________________
  #20 (permalink)
Old 06-28-2009, 08:10 PM
You make good sense, thanks. That sounds like a plan. So, as long as the sacrifical replacement (clutch drive) spins, it'll be good enough to tide me over. The main thing is just to maintain/restore the belt routing.
Tags
87 , 95 , ac , air , bronco , charge , clutch , compressor , conditioner , diy , f250 , ford , location , orifice , oz , r134 , replacement , tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
