Need ABS help
Need ABS help
I've been lurking around here for quite a while but have never got around to posting. I'v got 4 Ford trucks / 6 if you count my sons Rangers. We have a 32, 56, 64 and an 05. The boys have a 99 and an 01 Ranger.
Question that I have is that I took my 05 apart to do a brake job on it. I have a SSBC 3 piston caliper kit from Troyer that has been on the truck for a couple of years. While it was apart I noticed that passenger side half shaft was going bad. I replaced that as well as the hub that has the ABS sensor attached. When you get the hub from Ford it comes with the harness for the ABS sensor attached. I just detached it and attached the harness/sensor that was still in the truck to the hub.
Brakes work great now but the ABS light is on, although the ABS seems to be working. If I check for a DTC with my reader it tells me that there are no DTCs recorded.
Any one have any ideas on how to re-set the light? Does everyone think that it may be an issue to use the sensor that in the truck before rather than the one that came with the hub assy.?
