Lower Idler Pulley
Lower Idler Pulley
This is for a 1997 F250 7.3L PSD 149K
I recently had to replace the lower grooved idler pulley. In doing this i noticed that there was a plastic bushing on the bolt that was about 25% gone due to the pulley bearing ceasing up and causing the bearing to seperate from the pulley. This may have caused the plastic bushing to partly melt away.
What i am in need of is a replacement plastic bushing OR if needed the bolt+bushing. I used a Gates grooved idler pulley and HD serpintine belt.
So far so good, BUT being that part of the bushing was missing when i reinstalled I would feel better about repairing it right before gettign left on the side of the road.
Thanks for all who reply.
This applies to a Ford F150 SuperCab, 4.2L v6, Rear-Wheel Drive:
I too had a seized lower idler pulley. The P---S----- [parts dealer] adviser suggested that a smooth pulley was OK [the grooved version was not available, maybe?].
Also, the plastic bushing/collar is partially melted away. Here, the adviser suggested that the bolt holding the pulley has a shoulder that holds the bearing in place and suggested that the bushing/collar is not absolutely necessary.
Does anyone have any opinion on this? TIA
Farmerjeff
12-29-2016 09:16 AM
Kingkoopa
11-08-2013 03:49 PM
