97 F-150 running rich
Old 04-17-2009, 12:26 PM
Dusky Man's Avatar
Dusky Man
Dusky Man is offline
This is a 97' F-150. Truck runs rough at idle. As I come to a stop the enginge goes to a low idle and then will shut down. Starting to get some blueish smoke at start up. Egg smell at exhaust. MAF was cleaned, new o2 sensors and the fuel rail diaphram does not shoot fuel while running. Any ideas?? Can the MAF be bad?
Old 04-17-2009, 05:26 PM
Ron W.'s Avatar
Ron W.
Ron W. is offline
Blue smoke is burning oil, plugs might be fouled.
Egg smell could be a bad converter, excess oil can ruin a converter.
If the M.A.F. sensor is bad you should be able to disconnect it and the truck should run normally.
Low idle and stalling could be the I.A.C.
Fuel pressure regulator doesn't "shoot fuel"? If it's bed there will be fuel in the vacuum line that attaches to it.
When's the last time you replaced the plugs, f/filter a/filter etc?
Old 04-17-2009, 09:17 PM
Dusky Man's Avatar
Dusky Man
I am very consistent with normal maintenance, filters were about 2 months ago plugs/wires have been 3 months now. O2 sensors were about the same time. Cleaned the throttle body 4 months ago. Could I have put the plug wires on wrong. ? I read in another forum that the cats are clogged. Will clogged cats cause all these symptoms?
Sam.I.Am
1997 - 2003 F150
03-22-2016 09:03 AM
Ford_Six
General Automotive Discussion
04-01-2015 12:41 AM
Mark1182
1997 - 2003 F150
12-27-2014 04:36 PM
KAGAN21
06-22-2014 09:49 PM
Quick Reply: 97 F-150 running rich
