Need help with 88 Ranger 2.9
#31
#33
on
1 Post
96 (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
(R) AIR Bypass (AIRB) not working - Air Injection
(M) (Service 87 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
Again, sounds as if the relay is faulting either due to a bad relay or bad connection. Over or under-pressure in the fuel rail will contribute to the problems you're describing. So will a dirty throttle body/intake/idle air control.
#34
Right below the throttle body, on the front of the engine, around where the coolant hose comes out. You should see two sensors in the engine block. Here is a picture. Looking at the front of the truck, you want the sensor on the left. Unplug this sensor, and plug your map back in.
Here is a picture of the sensor.
#35
#38
on
1 Post
Bad connection or bad wiring to/from the TFI module, module is failing, the stator/pickup is failing (inside distributor), or you have a bad ground connection somewhere - specific to the return of your PIP / TFI module signals.
#40
#41
on
1 Post
They must've started doing that in '88 or my legend is worn off on my '87 BII... I don't recall seeing that on the underside or the top of the cover, nor did I have any fuses in the engine compartment (other than the one on the negative wire that goes to the neg. battery cable to the radiator core support... or to the computer or some such, I forget where it goes exactly), just fusible links. Whichever relay is for the fuel pump should have an Orange with blue stripe wire going from the contacts to the inertia switch, if I am not mistaken. I don't have my wiring diagrams in front of me, but that sounds about right.
#43
#44
on
1 Post
Yeah, overdrive would not work. Need the same computer for same computer to swap. And to add to this, it's not necessarily true that a partially faulty ECU will cause the truck to not run at all. Sometimes, part of the ECU assembly gets messed up or a connection is bad, etc. and causes problems. I do agree that all the sensors and connections need to be thoroughly tested and checked before ECU replacement is considered.
