abs pump humming wont stop!
Hi were on vacation in fl and we arrived on fri and i shut off our expy and the abs pump or whatever it is was humming and was loud. I had to unplug the 2 wire plug going to it to get it to stop. everything works but the pump never stops humming. any ideas?? the noisy thing is right under the master cylinder its a 2000 expy 5.4 4wd thanx to all!! ps the abs light came on when the noise started and is still on.
I have the same problem with my 2000 Expi - just happened today. So I came to FTE (like I always do) and found that no one replied to your inquiry.
I accomplished the same thing with regard to the noise/vibration; I took the 50 AMP CB out of the Engine Bay fuse box. So, now I have no ABS for sure! My "Ethel" has 200,400 proud miles on her. It's a 2wd, 4.6. Ford Experts!? Unite! Reply! Please! What is up with this 'unit'?
Thanks - Fred (in Orlando!)
itswillist
1999 to 2016 Super Duty
10-10-2010 07:16 AM
