Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-17-2009, 07:03 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Garage is empty, add now
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
PRNDL linkage adjustment
This is on a 2000 F-250 Triton V-8 (I know, not diesel but you guys are the bomb)
I got a friend that is having to slam the shifter into park to get it to start. I know there is an adjustment some where under the dash or column.
Now I think of it, I believe he said the truck still wants to roll when he puts it in park so maybe the linkage to the tranny needs adjustment.
In either case where would be the best place to adjust. Please forgive me because I am more of a manual tranny guy.
__________________
97 F250 Rosewood Stage II.75's, DP Tuner Live Tuned, Modded H2E, Terminated HPOS, Comp 910's, ARP studs, Swamps Pushrods, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch, RSK, D60, SD 1 ton springs DRD INMATE # 40
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #2 (permalink)
Old 04-17-2009, 08:10 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.mueckster has a spectacular reputation.
Roland Mueck
Cable and Bracket Adjustment
Place the gearshift lever in the (D) position.
Place an eight pound weight on the gearshift lever. (Just apply some downward force on th lever)
Raise and support the vehicle.
Disconnect the transmission shift cable from the manual lever. (Lever on left side of Trans)
Unlock the lock tab on the transmission shift cable.
Place the manual control lever in the (D) position.
Place the manual control lever in the first gear position.
Move the manual control lever two detents to the (D) position.
Connect the transmission shift cable to the manual control lever.
Lock the transmission shift cable lock tab.
Lower the vehicle.
Carefully move the gearshift lever from detent to detent and compare with transmission settings. Verify that the vehicle will start in PARK or NEUTRAL and backup lamps illuminate in REVERSE. If not, Steps 1-5 must be repeated and include digital TR or TR sensor adjustment in NEUTRAL. Readjust if necessary.
Name:  shift cable adjustment.gif
Size:  4.1 KB This picture may be showing the direction for re-latching the tab, but you get the idea.
__________________
Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6 (live tuned), AFE II w/ Pete's Cover, GTP38R w/ Riffraff billet whl & 1.15, 6.0 Techni-cooler IC, Full Force SS Injectors, Stealth HPOP, Fluidampr, Melling M-208, Walbro FP, mueckster Reg Return & Bowl delete, 910 Springs, mueckster 4R100, 4" SS MBRP, 6.0 Trans Cooler, billet 710 cap, Truetrac rear
PAA Member #62
... From Rock to Rocket-- Thanks to the Brotherhood.
  #3 (permalink)
Old 04-17-2009, 08:32 AM
Thanks Roland.
Is all of this done under the dash or under the truck.
__________________
  #4 (permalink)
Old 04-17-2009, 08:43 AM
mueckster's Avatar
Roland Mueck
Quote:
Originally Posted by Neal 97 250 View Post
Thanks Roland.
Under the truck. The only thing done inside is the moving of the shift lever.
See edits in my previous post.
__________________
Roland-
PAA Member #62
  #5 (permalink)
Old 04-17-2009, 09:56 AM
Thanks Roland I understand it better now.
Basically what we are doing is just removing the cable from the lever on the tranny. Then cycling the tranny thru a couple of gears and reattaching it to the cable.
It should then be readjusted.
Do you think this can be done with no tools?
I would assume at a minimum some pliers would be useful. Sorry for the dumb questions, I don't have it in my posession right now to look at it and don't have my tools with me.
__________________
  #6 (permalink)
Old 04-17-2009, 10:00 AM
mueckster's Avatar
Roland Mueck
Pliers and a screwdriver should be all you'd need. The tab will release and allow for the "teeth" on the cable end to slide to a new position, if necessary, to adjust the length.
__________________
Roland-
PAA Member #62
  #7 (permalink)
Old 04-17-2009, 10:40 AM
Thanks for all your help and the pic.
Reps sent Amigo
__________________
  #8 (permalink)
Old 07-28-2010, 08:52 PM
Enforcir Enforcir is offline
Enforcir is starting off with a positive reputation.
did this procedure work ?
  #9 (permalink)
Old 08-30-2011, 05:53 PM
T8R's Avatar
T8R T8R is offline
T8R has a very good reputation on FTE.T8R has a very good reputation on FTE.T8R has a very good reputation on FTE.
What would cause a sloppy feeling shifter to 'snag' going from N to P? (Parked the truck, and it apparently wasn't all the way in P... rolled down the driveway towards a neighbours SUV... the repairs of which I'll be paying out of pocket.)
Still snags a little bit every time I put it in park, although I'm pretty diligent now about double checking it and using the parking brake. Has anyone else run into something like this? I'm too afraid to let my wife drive it... or more importantly... park.
__________________
RoB
F250 2WD Crew w/ bigger torque converter, ISSpro guages
Recently installed: 6637 intake, MBRP 4" exhaust, Riffraff High Pressure Crossover, Garrett Power Max BB turbo, Stage 2 Single Shot Injectors and DP tuner. Thanks to Clay at Riffraff. The cup holders previously mentioned in my sig. are going to have to wait.
  #10 (permalink)
Old 08-30-2011, 10:35 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
2000 Ford F-350
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Sucks about the incident.
Try some of these yours is likely the first link with the torx screws being loose they can be tough to see, but once you know where they are you'll understand what they do, one of mine was actually sheared off, I reinstalled allen head bolts with locktite to prevent them from loosening up any more.
Sloppy Shifter
Pointer Adjustment
Normally I would include this thread too for all the adjustments but since you were here didn't figure you would need that one.
__________________
Alan 2000 F-350 CC SRW 4WD, DIY FRx, DIY CCK, Tyrant Tuning, BTS Trans, SpringerPop's Disabler, 6637 Filter, ZooDad, OCR, DIY Hutch Mod, Gutted EBPV, Foil Delete, 50Cent Mod, Muffler delete, other stuff...277,000 Miles and counting.Towing 2005 32' Sandpiper 5'er
2007 F-250 CCSB 4WD-Stock 73,000 miles.
Member Arkansas Chapter
Tags
01, 4r100, 97, adjust, adjustment, cable, expedition, explorer, f150, ford, linkage, prndl, procedure, shift, shifter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
