Lower radiator hose 97 expedition - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-12-2014, 05:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
Print Wikipost
Old 04-16-2009, 10:25 PM
lilslammer lilslammer is offline
lilslammer is starting off with a positive reputation.
How do you remove the lower radiator hose on a 1997 expedition? I tried everything with in my limit to remove it. I pushed the tab back, tried to twist 45 deg. to either side and nothing. I would rather not cut the existing hose. Any ideas? Thanks in advance.
Old 04-17-2009, 12:13 AM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
cut it off with a razor knife!
Old 04-17-2009, 01:03 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
You twist it the 45 degrees and pull like there's no tomorrow. It can be a real nightmare to get off if it hasn't been removed before.
Old 04-17-2009, 08:40 AM
jnicita jnicita is offline
jnicita is starting off with a positive reputation.
NOT to thread jack, but I'm sure he's going to be in the same boat as I am once he gets it off, HOW THE HELL DO YOU GET IT BACK ON?. I broke the plasitic tank on mine, ordered a oem replacement, added the 2 rings to the lower connector, and then bolted the radiator back in place. It was a bear, but I was able to at least get the new hose assembly started onto the radiator. It doesn't just want to push on that's for sure, I used a screw driver and gently pushed on the metal ring the same way I push the tab flat, but barely got it to the first oring. I have the old radiator, and the old hose, and have cut the metal end out of the old hose so I can see how it lines up on the bottom, so I can confirm that I am at the correct location for the hose to completely go on, but 3 hours later, its gone nowhere fast. I even went online to waste my money at mitchell1's eautorepair (Can you say biggest WASTE of money ever, they dont even mention a lower radiator hose in any of the documents you can read, I guess its just magic or something..)
Thanks in advance, sorry to thread jack lilslammer, but your gonna have this question next...
-John
Old 04-17-2009, 09:32 AM
Quote:
Coat the o-rings and the rest of the fitting with Vaseline. That'll make it a lot easier to slide on.
Old 04-17-2009, 11:31 AM
Thanks, 1 more question. My truck was bought used, and I'm guessing that the previous owner didnt realize that the tab'ed fitting was on the radiator, as when I removed my readiator, the fitting was still on the lower radiator fitting. Looking at the old hose, it looks like someone cut off the plastic trim that works with the weird fitting on the end of the hose and simply stretched the now 1/2" shorter hose onto the nipple and used a traditional hose clamp.
My question, is do I need to still use a hose clamp? I'm figuring since it has such an elaborate lower hose connection, that it is supposed to replace the need for a hose clamp.
Thanks
Old 04-17-2009, 08:46 PM
Without the plastic ring around the hose you will have to continue to use the hose clamp unless you replace the hose.
Old 04-17-2009, 10:00 PM
New Rad., new hoses.
yeah, all new parts, top/ btm hose, 3row all alluminum radiator, just making sure the twist on is all i need at lower on rad. side
Old 04-18-2009, 06:37 PM
I appreciate all your feedback. I'm made the assumption that it would be easy to remove. "Wrong" is an understatement. Once I turned the hose 45 degrees, I had to pull and wiggle like hell. Was not easy but I did not give up. Went back on the new radiator the same way. No leaks.
Old 04-18-2009, 11:33 PM
Those fittings are call quick connects. No one ever said they were quick dis-connects.
Old 04-19-2009, 02:11 PM
quiuck connects my ***. I spent 3 hours yesturday and another 2 today. Vaselline, a&d (cause I ran out of vasaline the first 5 attempts saturday.) I'm actually temping takeing the radiator out again. Of course, I dont have a OEM radiator. Well its supposed to be OEM, but who knows here it claims oem replacemet -> 98 1998 Ford Expedition All Aluminum Radiator | GenesisAutoParts.com
With the vaseline, the thing slipped right on to about 1/4 inch or so (just barely past the 2 ring) and the rear hose then almost poped onto the back by itself, it almost looks like the tab started to rotate closer to the place where you bend the tab, but by pushing back just a bit, I can tell its barely over the 2nd ring.
I've disconnected the rear hose, and twisted, I even pulled the rear hose back over against the frame there, hoping that it would push itself on. Im going to pull it off one more time (Not easy as you said). And make sure I have the entire metal portion of the inside of the hose coated, then Im bringing the hose out and cutting the plastic piece off and taking the metal out, what the hell is wrong with hose clamps anyway, why all the hokus pokus crap..
Anone in San Diego want to make 100 bucks, seriously, this is BS...
Old 04-19-2009, 04:01 PM
That's why the second time I needed to R&R the hose I cut the plastic ring off and used regular hose clamps.
Old 04-19-2009, 06:43 PM
I never got it past the 2nd ring, the metal the tab is on, is barely over the 2nd ring. but the damb hose rotates into the "tabbed" position, Makes no sense, I didn't think it would turn until it was all the way on. Anyways, the two of us couldn't get it on any deeper so I said what the hell, and pushed all the other hoses onto their corresponding locations, and put adjustable hose clamps on the block side, the reservoir, and the 2 going to heater. and started it up (didn't put anything on the fitting going to the lower radiator, as I said, only push on 7/8 and twisted to resting location. No leaks, I let it run, turning on the heater and ran it until the air got hot, ran it another 5 minutes and then turned off the heater. The truck barely got to 1/2 way, and held there. I seem to remember that there was a weird procedure on the trucks since they don't have a radiator cap at the top for air to be forced to, but as it sits right now, its not leaking, (I'm debating on 2 options, take it to our local mechanic or cut the ring off with a portable dremel and dismantle it off the radiator and then attach it with a clamp, I need the truck wed, and with work, I only have a few hours each night, so trying to get it on, I dont have the time, I'll pay for a shop or do the cut, anyone want to tell my why I cant do the cut (especially if I don't shorten the hose length making a gap stretch? I seem to remember once the plastic is off, the hose will pull apart from the metal contraption inside it, leaving me a OEM hose, minus 1/4" or so with no sleeve in the middle?
Thanks
-john
Old 04-19-2009, 07:14 PM
Yes you can do the cut. When I cut mine I just used a razor knife with a new blade.
Old 04-20-2009, 07:12 PM
orleec's Avatar
orleec orleec is offline
orleec is starting off with a positive reputation.
How long & at what mileage does this lower hose need to be replaced? I have 135 miles on my 99, and dread the thought of replacing that hose, apart form the fact that it's kind of pricey.
F250 radiator hose huskyfan68 Cooling, Heating, Ventilation & A/C 2 05-21-2015 12:23 PM
hose still leaks... duckdaddy Modular V8 (4.6L, 5.4L) 1 08-13-2014 02:30 PM
Radiator hose RobbD 1997-2006 Expedition & Navigator 3 12-03-2013 11:04 AM
2007 expedition lower radiator hose gahoghntr 2007 - 2014 Expedition & Navigator 0 01-31-2011 11:30 AM
Lower Radiator Hose Removal Tip jimkari 1997-2006 Expedition & Navigator 9 07-18-2008 11:07 AM
Tags
1997, 2000, 2003, 99, bottom, connection, expedition, f150, ford, hose, lower, radiator, removal, remove, removing, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
