1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
05 Navigator Problem
Old 04-16-2009, 07:45 AM
Mr. Hatt's Avatar
Mr. Hatt
Mr. Hatt is offline
Hi all, last Thursday my check engine light came on and I noticed my truck was idling little rough. So Saturday, I took it to the dealership and they said it was a code 442 which indicates a loose gas cap or a vacuum leak. The mechanic also asked if I leave the vehicle running while fueling (in which I plead guilty). Anyway after a slap on the hand and paying for a half hour in labor, he reset the computer and the cam (?), surprisingly Big Ella ran like new again. Until this morning, I started her up and the check engine light popped on again! What should I do? Will this continue to happen until the air gets out of the system? I really don't want to go back to the dealership for another raping!!!
Old 04-16-2009, 08:52 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
There's no "air in the system". Perhaps your gas cap isn't sealing properly and needs to be replaced. The reason you aren't supposed to run the engine with the cap off is because the gas tank gets pressurized as part of the emissions control systems.
You can reset the computer yourself by disconnecting the battery for 10 minutes, or go to a place like Autozone and have them scan for codes and reset it for free.
Old 04-16-2009, 12:08 PM
heymrdj's Avatar
heymrdj
heymrdj is offline
Don't mean to hijack, but when I'm on my long 1,000 mile plus trips on in the 04, I really don't ever shut the engine off that entire day, including for refueling. Is there any damage that can be done by this? I rarely take it to the point of kicking the pump, it normally gets between 3/4 and full.
Old 04-17-2009, 07:12 AM
MAS365's Avatar
MAS365
MAS365 is offline
Same here. Just went to Florida around 1000 miles one way and did not shut the motor off when we filled up and ate drive through restaurants. No problems down or back.
AJB201
04-04-2012 05:09 AM
FI460
1999 to 2016 Super Duty
04-09-2011 11:53 AM
Netofox
1983 - 2012 Ranger & B-Series
03-19-2011 03:16 PM
Weatherman1
05-13-2008 08:30 AM
MaLLoF150
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-08-2008 05:10 PM
Quick Reply: 05 Navigator Problem
