vacuum leak & oil in throttle body - Ford Truck Enthusiasts Forums
Old 04-16-2009, 08:36 AM
FordTruckGirl77's Avatar
FordTruckGirl77 FordTruckGirl77 is offline
FordTruckGirl77 has a good reputation on FTE.FordTruckGirl77 has a good reputation on FTE.
I havent worked on the EX in a few weeks and the pinging is still there. I noticed it has been getting slightly worse and yesterday it was at its worse.
my symptoms:
stumbles slightly at a stop
pinging up a hill and flat surface but not as bad
poor gas mileage
Well now its got a loud vacuum sound. Sounds like it could be coming from the throttle body area? Could it be the IAC? Also when we looked at the throttle body it had oil in it, could that be a failing PCV valve? I am going to swing by autozone this morning then go to my Mom's Ford dealer and get a tech friend to listen to it. I am just scared that this thing is dropping dead on me.
Any ideas???
Old 04-16-2009, 01:52 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Usually the V10 is rock solid. I wouldn't worry about it dropping dead. However you do have an issue.
I would replace the PCV and the hose that goes with it.
I would also pull the throttle body and clean it. It's quite easy to do with a can of carb cleaner. This will give you an opportunity to inspect all the associated hoses and connections for problems.
Old 04-16-2009, 02:01 PM
Pcv valve is going in right now at my husbands honda dealer the ford didn't have the hose so I ordered it the throttle body was cleaned 2 weeks ago. I will post more news shortly Oh and no codes at Ford figures
Old 04-16-2009, 02:02 PM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
After you do what Ken suggested if you still have a vacuum leak, a can of ether can be used to locate the vacuum leak. Spray small bursts of it around on the running motor where you think the leak may be. As soon as the ether finds the leak it will get sucked in and the motor will rev up. You found your leak.
Do not spray lots on there at a time since this stuff is still flammable. Small squirts here and there will help isolate the location of the leak.
Old 04-16-2009, 02:10 PM
Thanks neal we will do tha next this thig is frustrating. Forgot to mention when doing the plugs we noticed old rat dropping so who knows what type of damage we could be dealing with.
Old 04-16-2009, 02:40 PM
OK PCV is in and the shop foreman at honda found that the IAC is hissing!!! I was right and the bonehead at Ford was wrong!!! So I have the new IAC but no one had the gasket so I will do it tomorrow. I feel a ton better, and I am hoping that the X will be running like new tomorrow!
Old 04-16-2009, 04:11 PM
jesterdog jesterdog is offline
jesterdog is starting off with a positive reputation.
You can also just get a roll of gasket material and make a new gasket if you have to. I had to do that for the IAC on my '94 F-150 a couple of months ago. Nobody had them in stock.
2000 Excursion V10 pinging problem perryg114 Modular V10 (6.8l) 4 10-25-2013 03:28 PM
94 explorer 4.0L have big issues with excess carbon/ ping Milwaukee1979F150 Explorer, Sport Trac, Mountaineer & Aviator 9 10-04-2010 12:17 PM
Pinging sound Bifford 6.4L Power Stroke Diesel 11 03-15-2008 05:57 PM
88 EFI 460 Pinging, timing issues? Shawn MacAnanny Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 02-21-2007 10:27 AM
2.3 Pinging RangerXLT89 4 Cylinder Engines 5 12-27-2004 09:22 AM
Tags
02, 97, body, excusion, f150, ford, gt, leak, leaks, locating, mustang, oil, sound, throttle, v10, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
