Oil Level Sensor - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Oil Level Sensor
Old 04-15-2009, 10:13 PM
BII Plow Truck BII Plow Truck is online now
BII Plow Truck is starting off with a positive reputation.
Oil Level Sensor
Does the aftermarket like NAPA, CarQuest, etc sell the Low Oil Level Sensor for the 2.9L BII? Or is this a Ford stealer item only?
Old 04-16-2009, 12:58 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Last I recall, you had to buy the oil pan with the sensor. I have no idea if anyone, even the stealership sells them anymore. I can't seem to find a listing on any of my usual resources. Dare I ask why you're looking for one?
Old 04-16-2009, 08:35 PM
Quote:
Originally Posted by kernel-panic View Post
...Dare I ask why you're looking for one?
I have to replace the starter, the sensor has been leaking for a while and it's there in the open with the starter removed. I run Amsoil synthetic and could leak out very fast once the gasket/sensor completely fails.
I ordered one from my local Ford dealer today.
Old 04-17-2009, 02:31 AM
Yeah, I have to take a look at mine when I get back home. I figure if it'll make it until the next full oil change (I am running Amsoil now as well, and the advertised 25k / 1 year between full oil changes might be entertaining...) before it's leaking bad enough to worry about, that will work. I may order the sensor and keep it handy just in case. On another semi-related note, mine still has the original starter (unless the original owner or previous owner replaced it with Genuine Motorcraft parts) and solenoid (maybe on the latter). Only thing I have had to do with it is replace bushings, brushes, and drive gear and bolt it back in place a little more securely with some locktite. The bolts had backed out on it for some reason (probably after it had been removed and reinstalled to facilitate tightening of the oil pan bolts by the previous owner) and the drive gear got munched. Flywheel is still pretty much okay, heh.
Old 04-17-2009, 03:26 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
F2AZ6C624B .. Oil Level Sensor (F2AZ-6C624-B replaced E4AZ-6C624-A) There's no Motorcraft part number.
Fits: 1986/89 Ranger/Bronco II 2.9L / 1986/97 Aerostar 3.0L / 1990/ Ranger 3.0L.
Fits: 3.8L, 302 & 351W's installed in passenger cars from 1984 thru at least 1988 (I didn't look any further).
MSRP: $48.62 // FTEpartsguy.com price: $35.00
Old 04-17-2009, 10:12 AM
Correction on my first post. The replacement oil pans that I saw listed a while back had listings for one with and one without the sensor hole. Thanks for the part # Bill, I'll check back here when it comes time to order one
Dead BII, '88 2.9L,5-speed, 4X4 DFWBII Bronco II 16 01-29-2011 11:32 PM
89 B II oil level sensor Avanti Bronco II 3 10-23-2008 12:45 PM
84 BII 2.8 C3 to 86 BII 2.9 5-speed B'II-Trapper Bronco II 1 03-18-2006 08:13 PM
89 BII oil level sensor Avanti Bronco II 2 07-15-2004 01:33 PM
Tire Recommendations 90 BII EB redbronco2 Bronco II 3 01-15-2002 01:46 AM
Tags
29, 302, 6c624, bronco, f2az6c624b, ford, ii, leak, level, low, oil, ranger, removal, sensor, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
