1993 f250 door won't open - Page 2 - Ford Truck Enthusiasts Forums
Old 04-16-2009, 05:09 PM
joe f350 joe f350 is offline
joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.
i have all types for hammers u guys will never let it die will u
Old 04-17-2009, 10:31 PM
gbeach gbeach is offline
gbeach is starting off with a positive reputation.
well took apart. cable had snapped at the door handle lever. I see how it comes off at the lever, but I can't see what is going on at the other end. do I have to take the 3 phillips screws out that hold the latching assy.
Old 04-17-2009, 11:17 PM
EMD_DRIVER's Avatar
EMD_DRIVER EMD_DRIVER is offline
EMD_DRIVER is starting off with a positive reputation.
Yes and you need to get the baggy off of it, to access the assembly..
Old 04-18-2009, 08:41 AM
okay, that is what it looked like. how does it hook in in the latch area.
Old 04-18-2009, 08:59 AM
EMD_DRIVER's Avatar
You'll have to turn the cable, to where the end piece will go in the hole. Once it's in the hole, straightening it will lock it in. I'm sorry I can't explain it better...
Old 04-18-2009, 09:28 PM
don't apologize, I understand, just wanted to make sure. from the picture of
the cable it looks like this
__
__|
Old 04-18-2009, 09:34 PM
sorry that didn't look right, basically it looked like straight left to right, then up 90 degrees, then straight left to right again._|- best i could do on a computer.
Old 04-18-2009, 09:37 PM
thanks for your help emd_driver
Old 04-20-2009, 10:49 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
FWIW, the cure for this very common problem is a new cable. Napa, Dorman have them available at your Local Parts store.
Dorman part number 924-300
If Your replacing inside door release handles, 99% of the time, its a stretched cable that is at fault.
When the cable stretches, You over compensate by pulling the handle harder, without even realizing Your doing it.
Old 04-20-2009, 11:11 AM
thanks for the part#. didn't think I would be able to get the cable locally
Old 04-20-2009, 03:06 PM
fonefiddy,
that part # is saying it won't fit my 93 f250, according to advanceauto.
Old 05-22-2009, 01:18 PM
fonefiddy,
don't understand why advance is showing that won't work for my truck.
seems like it should.
  #28
Old 05-22-2009, 06:32 PM
It will, I used them on My 93
  #29
Old 04-09-2014, 02:12 PM
Hollywood276 Hollywood276 is offline
Hollywood276 is starting off with a positive reputation.
Door cable fix. Free
My cable was stretched so before spending money I did a freebie. Should last. I removed cable from inside handle, twisted it in direction of braids taking out slack, and put it back in handle. Works like new.
might have destroyed my injection pump idi1993f350 1987 - 1996 F150 & Larger F-Series Trucks 5 09-15-2016 07:53 AM
dome and cargo light issue levgoo 1987 - 1996 F150 & Larger F-Series Trucks 2 06-12-2015 11:46 AM
Sliding Door Latch Hangs (2000 E-250) perpetualjon 1968-2013 Full Size Vans 3 06-01-2014 11:21 AM
99 Crew Cab Rear Door issue X1Lightning 1999 to 2016 Super Duty 3 04-28-2014 12:03 PM
2001 F-250 Ext. Cab rear door bholt 1999 to 2016 Super Duty 2 12-02-2012 07:40 PM
Tags
19921996, 1993, crewcab, door, doors, drawing, f250, f350, ford, handle, hard, inside, open, rear, replace, supercab
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
